SL55/63/65/R230 AMG: Climate control nightmare
Old Dec 7, 2020 | 03:24 PM
M113kFreak's Avatar
SL55AMG
Unhappy Climate control nightmare
Hello fellow Mercedes owners,
(Apologies if I bore you with this long paragraph and thank you for your help!)
I just recently purchased an SL55AMG from selling my E55 amg so I am familiar with the drivetrain but not the platform of the SL and was wondering if someone can shed some light on this issue in hopes for avoiding the stealership. So I purchased a 2003 SL55 AMG with around 62k miles and due to the mileage I wasnt really thinking that electrical components could fail at such low mileage I didnt bother to test out all the climate control functions as it was summer time and I was mostly worried about the Vario roof issue it was having but the A/C worked wonderfully. As the the weather started to get colder here in NE I went ahead and decided to disable the A/c And turn on the heat. I noticed that on the N22 Climate controller button where it says (A/C off) and its supposed to illuminate red dot to indicate that it has turned off the A/C was turned off was stuck on meaning I no matter how many times I pressed the button I could never turn off the A/C. Upon further investigation I checked all relays fuses looking at the fuse panel diagrams I was not able to pinpoint anything relating to Heating climate control. I then went ahead and saw online some people suggesting its the common heat control valve right in the cowl and changed that too with no luck. I did pull some paperwork and noticed that the rear SAM was replaced due to it being faulty by a Mercedes benz specialized shop chasing down Vario roof issues so I went ahead and inspected that SAM which seemed fine. Someone at some point was in the passengers side footwell testing voltages because two of the Can-Bus wires were slightly stripped and exposed. Regardless, I did not see any issues with the rear SAM as I ended up budging and bought a scan tool which gives me some functionality and data or errors. I ended up taking apart to inspect the from passanger underhood SAM to inspect the plugs and fuse panel which was corroded from water exposure so I ended up replacing that and that seemed to fix the AC button illumination and all the buttons seem to lite up fine and function normally. The issue that I am still having is that the signal is not being sent to the Heater control valve so it opens the door for coolant to flow into the heater core.
Old Dec 7, 2020 | 09:06 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
so you have to find out where the signal or voltage comes from, that supplies the heater valve. good luck
Old Dec 8, 2020 | 08:40 AM
M113kFreak's Avatar
SL55AMG
THanks for stating the obvious Plutoe...
Old Dec 8, 2020 | 08:42 AM
M113kFreak's Avatar
SL55AMG
Okbarnett, I was wondering if someone went through the same issue on one and if its common so I can bypass trying to find some sort of wiring diagram which I do not have.
Old Dec 8, 2020 | 03:21 PM
BenzNinja's Avatar
Former Vendor
https://mbworld.org/forums/sl-class-...rams-r230.html
Old Apr 30, 2021 | 07:15 PM
Banditos's Avatar
2005 SL 65
Did you ever get this resolved? Having the same issue where the middle buttons are unresponsive. The dials all work fine.
