SL55/63/65/R230 AMG: ABC question
Can anyone tell me what it means when my red ABC warning light is displayed when in sport mode and hit some minor bumps in road?
It doesn't happen as easily when sport mode is off, but it does occur. Also, my ABC light appears whenever I drive over a hump in the road where the car may become slightly airborn. Do those symptoms point to something specific that I need to do or repair?
Thanks,
My buddy stopped by with his SL55 on coilovers without sway; I didn’t noticed any “very disappointment” difference.
Tons of guys done the conversion and haven’t reported any disappointment. Hmmmmmmm
did u try going fast or taking turns in the car without sway bars?
the original ABC will likely both ride & handle better than a coil over kit. That’s the entire point of an adaptive suspension; giving less compromise between the 2. You can get coil over to handle better (certainly not without a sway bar though) but it’s gonna ride like a lumber wagon (just read reviews on the sl65 black series).
there’s been a lot of people regret going to coilover. Look at the CL & S class forums where it’s more common
think my main concerns are the hydraulic lines bursting. A few line configuration are under the subframes...if they start leaking, I’d hate to deal with that.
What coilovers did you end up using? What swaybar(s) would you recommend?
