SL55/63/65/R230 AMG: 2005 SL55 AMG question
It's been awhile since I've been on MB World. I've owned later AMG cars and am now researching the 2005 SL55 AMG. In my area there is one for sale with only 6,000 miles.
From what I've read, the reliability for these is pretty good. Are there any specific things that could be a problem for one that has been garaged and rarely driven?
Thank you
-Find out when the tires where last replaced. If over 4 years old(maybe even 3) you can bet they're hard as rock and need replacing. Approx $1200 or so installed.
- Ask the owner if any corners of the car sag at all after sitting and how long until it sags. If he says it never does chances are very high he lying. Even perfectly operating ABC systems one corner will sag after a few weeks of sitting. Also make sure all shocks and valve blocks are checked for seepage.
-When was the last time the ABC was flushed, Brake fluid flush, air filters, spark plugs, etc. Chances are this garage queen probably needs all new fluids and filters. Probably another 1K-1.3K or so at a good Indy shop. Just basically a good tune up overall.
- Ask when the last time the two batteries were replaced. If the starter is more than 6 years old probably need a new one soon and Aux. battery(trunk) they seem to go out about every 3 to 5 years. Car needs to on a battery tender if your not driving it more than once a every 5 days or so.
-Make sure roof is all operational feel along the driver and passengers side edges for any wet spots from leaking system.
-Ask if motor mounts, trans mounts, rear mounts have been replaced. Chances are these all need replacing.
-Even brake pads that old could be brittle.
Overall get a PPI done on this car at Indy shop that works on Benz's often. The few hundred bucks that cost, might save you 10K easily. If the ABC system is in rough shape that alone can run 8K to 10K for an all new system and lines. On top probably another few K of other things that need to be done.
Beyond that the engine and trans on these cars are pretty damn strong. They both can handle a lot power. You get this car sorted and chances are it will give you little headaches moving forward outside of just maintenance. Other good news the prices on these cars have bottom out for the last few years and actually have started to creep up some. But overall this car is still a buyer market because of the high cost of potential ABC issues.
