SL55/63/65/R230 AMG: The hunt for mechanically sound sl55
Go buy a Toyota you pessimist
My SL55 also came with a $5000 ppi list, just different parts. Tensioner and idler pulley bearings bad, valve cover leaks, overdue service, noisy roof… I do my own work, for the same $5k the dealer wanted I am fixing everything and giving it a serious under the hood update too. Find a good Indy and the best car you can justify the purchase price, get everything fixed and enjoy!
You made the right call in buying an '08 SL55, as it came with the upgraded and notably more robust ABC 2.
You made the wrong call in taking it to the dealer and then again by returning that car. Literally had the ideal year for an SL55 with only routine maintenance on the agenda. That was a solid example.
If you take an old car to an establishment whose enrichment is based on performing car repairs, what is your expectation of the result of an inspection? A long list of work intended to enrich the establishment. It’s how it works. Don’t expect otherwise.
If you don’t DIY, and you don’t have a limitless flow of cash to pile into an old high performance German sports car, don’t buy one.
On the other hand, if you are able to and have the desire to pour large quantities of cash into this type of car, continue in the search.
