SL55/63/65/R230 AMG: SL 55 AMG check light and limp mode
I have bought my SL 55 a few weeks ago and today was good weather to drive. I floor it on the highway and the car went to limp mode and the check engine turned on. I turn off the car and drive it again so everything is right. But still the engine light on and whenever I floor the car it goes to limp mode.
Anyone has been in this situation before. And what can be the problem. Note the car has just 32000 km.
How much did cost you to fix it. Btw I got just check engine light nothing with ESP
hello there
Did you get a code for the accelerator pedal? Because I’ve got the same issue but without any codes!
Shimming the pedal assembly so it doesn’t push down so far repairs the issue, as it isn’t necessarily a problem with the electronics. My sons car would do it every time he pushed the pedal all the way down. I glued a small washer right where the pedal hits the stop, and it doesn’t anymore.
Oh ok I get it now, so basically there isn’t a code for it you just see the symptoms of it
