SL55/63/65/R230 AMG: Replace windshield washer nozzles
Old Nov 18, 2021 | 11:16 AM
Tomcat SL's Avatar
2004 SL55 AMG
I am looking for a source and a DIY instruction for replacing my clogged/misaligned windshield washers (2004 SL55 AMG). I have tried to use a needle to unclog and align BUT no luck.
Thanks,
Tom
Old Nov 18, 2021 | 02:56 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
have you pulled the water line off and see if the have good pressure
Old Nov 18, 2021 | 06:33 PM
Tomcat SL's Avatar
2004 SL55 AMG
Yes...one port on one side is clear so 4x the pressure is coming through one nozzle.
Old Nov 19, 2021 | 04:36 PM
okbarnett's Avatar
you should be able to get them from a dealer or ebay or autohausaz or eeuroparts
Old Nov 29, 2021 | 01:26 PM
MK19's Avatar
Just sold my '11 Porsche TurboS cab for an '03 SL55!
You might try back flowing the disconnected nozzles with compressed air, after assuring there's no crud you can remove from the inlet ports. I don't thing I've ever had one that couldn't be cleared, but I have replaced them when my cleaning with tools has degraded the spray pattern.
Old Dec 3, 2021 | 05:41 PM
Nor Cal SL55's Avatar
2012 E63 AMG
I had a leaking line and had MB replace the hoses from the windshield to the reservoir. The nozzles worked fine otherwise, and I asked to have the old parts back so I could see for myself where the leak was occurring as they charged me a lot for replacing the hoses. You can have my old set of lines if that will help you,
Old Dec 3, 2021 | 07:17 PM
Tomcat SL's Avatar
2004 SL55 AMG
Thanks, I think my hoses are okay...BUT I will investigate further and may take you up on your offer.
Old Dec 14, 2022 | 01:44 PM
Tomcat SL's Avatar
2004 SL55 AMG
Can anyone tell me the part #. Driver's side (left) 2004 SL55 AMG Windshield Washer Nozzle?
Old Dec 15, 2022 | 09:28 AM
WillGess's Avatar
2004 MB SL55 AMG
I had a local trusted shop replace both washer nozzles a couple years ago. Part number on the receipt: 230 860 03 47. 2004 SL55 AMG.
On Sunday, the driver's side headlight washer shipped fluid on the floor. I'm guessing the nozzle assembly needs to be replaced. And so it goes.
Old Dec 15, 2022 | 09:44 AM
Tomcat SL's Avatar
2004 SL55 AMG
Perfect, thanks! I was getting conflicting #s.
Always something to work on!
