SL55/63/65/R230 AMG: R230 M156 SL63 motor mounts
Could it be something else?
Are urethane mounts worthy for an upgrade over stock?
You may need Hub rings. Take a wheel off and measure the hub size on the wheel.
Mine were 76mm. The car hub size is 66.56 If the wheel hub opening is not 66.56 you will need hub rings.
You can get them most any size. If you cant find the ones you need, let me know
Also make sure the lug bolts are correct. Most mercedes seats are ball seats. most aftermarket wheels
use cone seats. I did this to my car and At 140 mph I had no vibrations.
