SL55/63/65/R230 AMG: Transmission
Old Jun 16, 2022 | 03:34 PM
6444johnf's Avatar
SL55
Transmission
Purchased an MK Ultra TCU, Blue Solenoids, MB Oil & Filter, what else do I need to do when the transmission is opened?
Old Jun 16, 2022 | 04:00 PM
cdk4219's Avatar
95 SL600
Connector seal upgrade if it hasn’t been done.
Old Jun 16, 2022 | 04:01 PM
6444johnf's Avatar
SL55
Old Jun 20, 2022 | 06:36 PM
AMGenema's Avatar
2003 SL55 AMG
Going through this now. Make sure you do your conductor plate before you do anything. That will eliminate the issue with the car going into limp mode when you hit the pedal switch. I am working with Troy. He has been great.
Old Jun 20, 2022 | 10:08 PM
cdk4219's Avatar
95 SL600
What’s the pedal switch?
Old Jun 21, 2022 | 05:28 AM
AMGenema's Avatar
2003 SL55 AMG
There is a switch under the accelerator pedal that you use to reset your TCU learn mode. I’ve heard it also acts like a kick down switch for the transmission as well. Not sure about that mine usually kicks down way before i reach half throttle. My car would go into limp mode if I pressed on the throttle and depressed that switch. After I changed the conductor plate it doesn’t do that anymore.
Old Jun 22, 2022 | 09:15 AM
6444johnf's Avatar
SL55
Thanks for the advise. Part ordered!
Old Jun 23, 2022 | 10:00 PM
cdk4219's Avatar
95 SL600
In my limp mode instances under full throttle, accelerator pedal was overextended, causing the ECU to see to high of a voltage reading. I am not aware of a switch in this assembly. .
Not sure how the conductor plate remedied your situation, but the pedal assembly has fixed this many times. One of 230s I have did this, and a small spacer between the plastic pedal and base cured the issue.
eDd
Old Jun 30, 2022 | 05:27 PM
AMGenema's Avatar
2003 SL55 AMG
Interesting.
Old Jul 2, 2022 | 11:57 AM
RichInCanada's Avatar
none
does this apply to the SL65 AMG ?
I've seen in the past that there is a shifter pin upgrade or something but I cannnot find it...
Old Jul 2, 2022 | 12:16 PM
6444johnf's Avatar
SL55
Thought that was an inside the cabin part?
