SL55/63/65/R230 AMG: ABC suspension question.
Your mom's '04 R230 has ABC 1, which uses a valve block that can be rebuilt. Since the front suspension only sags after sitting for a couple of weeks, however, it could just be that the o-rings are a bit worn, but not yet damaged.
I experienced something similar with my S55 (which also has ABC 1) and was able to remedy it with a fluid / filter change and an additive that slightly swells older o-rings and restores their ability to seal.
More Info: https://mbworld.org/forums/sl-class-...e-oil-use.html
