SL55/63/65/R230 AMG: Harsh over bumps and swervy in sweeping turns
Now that I have done it once, I honestly think I could swap a strut in about 30 minutes after the car is on the jack stands! I solved a lot of small roadblocks, though, so if you have any questions, just reach out. Good luck!
If any strut is locked, I would suspect a bad blocking valve in the ABC valve block. Seems very unlikely it's a seized strut, but I guess that's possible. The blocking valves block fluid from leaving the struts when the car is parked. They use solenoids to open them. Bad solenoid or no electrical signal and the valve stays closed.
Keep us informed.
Also, I've had great luck with Arnott strut rebuilds. I think I paid about $800 for a front.
In terms of a "rebuild".......... nobody can properly test the valves, all they do is clean it up and put new o'rings in. And the most sensitive areas are the leakage at the blocking valves (these aren't really return valves) because even minor leakage causes the dreaded corner droop when the car is parked. I'd stick with OEM. However, that said, a new one is about $1500, and if you don't mind taking a chance with your labor, buy a used one on eBay for $1-200, but make sure the seller takes returns. Also note that there's an older one where the 4 solenoids are separate, and a newer one there the solenoids are integrated in pairs. The newer it is the better in my mind just because it's newer.
This is not a tough job, but If you haven't done it before, recognize that the hoses connect to the valve block with quick disconnects, however there is a special tool to decouple them. I've done it several times using needle nose pliers and similar fork like jury rigs, but it can be a pain and it's kind of hard on the QD's. I don't know where to buy that tool......but if you can find it, it's worth getting I think. Also be sure to bleed system pressure at each of the rear shocks. I'd jack up the whole rear end to avoid expelling all the fluid from the right rear strut that will otherwise collapse when the hoses or bleeders are opened.
Let us know how it goes and if you find that special too, drop us a picture and the source.
Motor mounts are a good culprit............trans mount is cheap and easy to swap. If you don't know the history of the motor mounts..........well worth replacing. They aren't that expensive, but they are a bit of a pain to R&R. If I recall, there's a special (but cheap) special wrench required. However, I'd say that the MM's don't affect handling at all and manifest as rumbling thru the body and vibration/noise. So, I am perplexed at this point given that you apparently are trying to address a chassis like issue. Is that correct?
Let us know.
I would really like to solve the problem. I like the car. I dont drive it often but love it when i do. I certainly dont want to sell it with problem known to me
a real conundrum
I believe a strut either works or it doesnt. My struts appear to work?
i cant imagine that a valve block could have a valve that only partially opens, or stuck partially open. My car is 2007 abc2. The car rides level and at consistent heights
i wonder if motor tranny mount can be inspected in place. I have hard time thinking these mounts are causing the problem but i bet they are stock, 20 yrs old.
This car used to drive smooth
If you've swapped the spheres and you know they are good, I would look at shocks/struts next. Are OEM units even available ?
The high speed wander/weave sounds like tires. I only run Pilot Sports on the SL and it tracks like a freight train. If you have different tires front and rear, that's a textbook cause for the behavior you have now.
- Active Adaptation: The factory ABC struts feature integrated control valves managed by a dedicated suspension Electronic Control Unit (ECU). Sensors analyze the vehicle's body movement, pitch, and yaw, instantly firming up the struts during aggressive cornering and softening them during highway cruising."
I still say if you have a rock hard ride, the shock is the cause. Now whether that is due to a physical malfunction in the strut or an electrical issue in the ABC ECU, that is certainly up for debate. Something is keeping that valve closed and limiting fluid movement in the damping part of the shock.
And here an Amazon link to the wrench that you will absolutely need for the job. Otherwise I think you'd have to pull the engine part way out.
Let us know if this does it for you.
- It is associated with the internal plunger/travel sensor (“plungerweg sensor” in Mercedes docs)
- Also provides diagnostic feedback
- Mercedes documentation notes that later facelift cars after ~2006 eliminated the plunger sensor in the strut and instead inferred information from pressure sensors. Used by the ABC ECU for additional hydraulic/strut movement monitoring (same purpose, different type of measurement). Both use a lever sensor at the lower control arms to sense ride height, and the ABC valve blocks adapt the flow to at each strut to maintain a level posture. None of this affects the damping, which I believe is fixed hydraulically inside the strut, although damping can be tuned for the strut positions is shocks, I don't know if that's the case with these but given the sophistication of the design I bet it a variably damped shock. Of course, all shock damp more the faster they are moved, so that's the inherent variable damping.
Here’s a simplified layout of the suspension:
Code:BODY / STRUT TOWER | | Electrical connector | for internal ABC | plunger sensor [ABC STRUT] | | ------------------- LOWER CONTROL ARM / / Lever linkage / [Ride Height Sensor] mounted to chassis F1: did you say you have a '09? and how may miles are on it? And do let us know is the motor/trans mounts do the trick. I can't wait!Spoiler
