SL55/63/65/R230 AMG: Transmission leaking
Old Dec 13, 2004 | 07:34 AM
ldye's Avatar
2010 R8
Best I can see it is leaking from the front of the transmission. I'm guessing a front seal. Is this something MB will repair or will they replace with a new tranny.
I'm not very happy to see this happening with only 5000 miles on the clock.
Old Dec 13, 2004 | 09:21 AM
blueSL's Avatar
SL55 AMG
Well, one puddle on the garage floor looks pretty much like another; could be the transmission, could be the engine, the brakes, the adaptive damping (ABC). My car lost its ABC fluid twice and was trucked in the second time. The under-body cladding makes it difficult to know exactly were it's coming from, needs to go up on a ramp and have the cladding removed.
I'd get the car in without delay and certainly before driving it any more.
Old Dec 13, 2004 | 01:40 PM
CASL55's Avatar
2004 SL55, 2005 E500 Wagon
I had a transmission leak at 3500 miles
I found Automatic Transmission Fluid (red, doesn't look like motor oil) on the floor of the garage. Not a puddle, just a few drops. I took it in to the dealer, and they found a faulty seal around an electrical fitting on the transmission. Dealer replaced it, and it's been fine since.
If your problem turns out to be a similar seal, maybe there's a broader problem than a random failure.
"Once is happenstance, twice is coincidence, and three times is enemy action." Ian Fleming.
Jim
Old Dec 13, 2004 | 02:21 PM
blueSL's Avatar
SL55 AMG
The electrical parts of a Mercedes transmission are immersed in the ATF fluid, so the seal around the electrical connector is important. Here's a picture of what sits in the fluid... you can see the connector at the top.
Old Dec 13, 2004 | 03:39 PM
ldye's Avatar
2010 R8
Got the leak fixed
it was the electrical fitting. My guess is that it was not installed correctly causing the leak around one of the o rings. My dealer had this part in stock. That tells me something.
Old Dec 13, 2004 | 04:20 PM
blueSL's Avatar
SL55 AMG
Agree with that, my experience is that Mercedes dealers hardly have anything in stock, apart perhaps from oil filters.
Old Dec 14, 2004 | 02:09 PM
JosanK's Avatar
2003 SL55 2007 S550
A friend has an 03 S55. Same problem. 16K miles.
Old Dec 14, 2004 | 06:31 PM
Xeron's Avatar
04 SL55 (sold),05 SL55, 09 SL63, 07 C2S cab Porsche,
same problem
watch for slippage afterwards. If so they need to replace the ETC
