SL55/63/65/R230 AMG: V8K engine noise upon cold start
Old Feb 2, 2005 | 10:05 PM
doltmo's Avatar
2006 Gallardo 6-speed, 2005 SL55, BMW X3
Is it normal to hear a whining/growling sound from the V8K engine for a few seconds after starting a cold engine? If I had to guess, it sounds like a lack of lubrication. After about 5 seconds it goes away - at about the same time the idle speed drops. When the engine is warm, this doesn't seem to happen.
This is on a brand new '05 SL55. My '04 SL500 made no such noise.
Is this normal?
Old Feb 3, 2005 | 12:56 AM
blueSL's Avatar
SL55 AMG
That's probably the compressor that you paid all that extra money for making itself heard...
Old Feb 3, 2005 | 02:09 AM
IanSL55's Avatar
'10 MB E63, '08 ML550 ('05 E55, '05 SL55, '08 E63 GONE)
I have the same thing and have 'heard' that it's normal... As chance would have it, I'm taking it into the dealership tomorrow for my pre-3000 mile checkup... I will ask the tech about it...
~ Ian
Old Feb 3, 2005 | 01:42 PM
doltmo's Avatar
~ Ian
Let me know what you find out. I'm only 260 miles into the first 1000/3000 checkup. If this is something abnormal, I'll take it in earlier.
Old Feb 3, 2005 | 06:20 PM
Kar don's Avatar
Mercedes-Benz
that is the air injection pump making noise for the first few seconds of startup.
Old Feb 3, 2005 | 08:54 PM
doltmo's Avatar
Did my '04 SL500 have the same air injection pump - or is this something unique to the V8K's?
It sounds like there's someone under the hood trying to cut a wet 2-by-4 using an old circular saw with worn out bearings - after 10 seconds it fades out and goes away.
If I turn the car off, wait a few seconds and start it again - I get none of this noise at all. Strange. You would think the air injection pump would come on every time the engine is started.
Old Feb 3, 2005 | 10:04 PM
IanSL55's Avatar
Just back with my car... 2500 miles. The tech said it's NORMAL on a cold start... and even had one of the sales guys fire a cold 55 that was on the lot. Same noise... though it sounds a lot worse in my enclosed garage in the morning.
~ Ian
Old Feb 3, 2005 | 11:31 PM
awiner's Avatar
2003 CL55 AMG
It's not the air pump. It is the Kompressor clutch/pulley. I have the same sound. Lasts for about 10 seconds at cold start.
Old Feb 4, 2005 | 05:22 AM
Chris 45971's Avatar
2005 SL 500
The saw analogy is a good one. I get this sound on cold start ups with my 500 as well.
Old Feb 4, 2005 | 12:00 PM
awiner's Avatar
2003 CL55 AMG
If you are hearing a "Saw" sound, it probably is your air pump going bad.
Eventually if it burns out you will smell it.
Old Feb 4, 2005 | 07:58 PM
2005 SL 500
Yeah, the sound is like a mix of between a miniture table saw (you know with the round blade) and a small vaccume cleaner. The sound is muffled and not harsh. It only happens when I start the car on cold mornings. After the car's been going for a few minutes, I don't hear it again. I believe that this sound is the same sound that everyone else is talking about. This is not normal?
Thanks for the heads up Awiner.
Old Feb 4, 2005 | 08:09 PM
2005 SL 500
and it only lasts for approximately 10 seconds.
Old Feb 4, 2005 | 11:46 PM
doltmo's Avatar
Chris' description of the noise he is hearing from his '500 is dead-on with what I'm hearing from the '55. I didn't think my '500 did the same, but I've been without it for the past 8 weeks waiting for the new '55 to arrive.
So it looks like the noise is from the air injection pump - and it's not uncommon (they all do that?). At some point I'd like to understand why the air pump makes this noise - like lack of lubrication, about to fail, etc.
Thanks to all who responded.
Old Feb 5, 2005 | 01:44 PM
cls55's Avatar
Thumbs up
hi
the noise you hear on start up is your power steering pump and thats normal.good luck with your car.
Old Feb 5, 2005 | 02:11 PM
awiner's Avatar
2003 CL55 AMG
LMAO... We have now 3 possible noises. I know what all 3 noises sound like and it is hard to explain over a forum which is which.
The "SAW" type noise is definitely the centrifugal air pump however.
