SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: dashboard gages wackey after battery insgtall
Old Apr 2, 2006 | 09:05 PM
harryco's Avatar
1999 SLK230
dashboard gages wackey after battery install
Reconnected battery (positive first then negative), heard spark when negative cable touched post. Dashboard gages are screwy, ie. no tach., no speedometer, gas and temp gages go crazy, odometer reads dashes, coolant light is on, dash lights are super brite and not dimmable, outside temp reads -38C and clock is set to 24hr mode. What happened! All fuses are fine. Is there a reset of some kind or a relay stuck (where are the relays). H E L P !
Old Apr 2, 2006 | 09:09 PM
harryco's Avatar
1999 SLK230
Sorry, forgot to mention:
1999 SLK230
Old Apr 3, 2006 | 01:06 AM
E-Klasse's Avatar
W205 C300
Was the key in the on position when the battery was reconnected or the doors open. Odd that they were zapped when things were off. You didn't reverse the polarity of the battery? There must have been a load in order to get a large spark.
Old Apr 3, 2006 | 05:16 AM
bazzle's Avatar
Remove Batt neg lead. Wait 30 mins.
reconnect.
There will always be a small zap due to capacitance in leads etc.
See how you go.
Bazzle
Old Apr 3, 2006 | 07:39 AM
harryco's Avatar
1999 SLK230
Key was not even in the ignition, doors were closed and nothing was on.
But why is the dash crazy?
Disconnected battery again, this time for 4 hours with same result (including spart).
Battery is still disconnected again and will be left there until overnight.
Old Apr 3, 2006 | 01:47 PM
E-Klasse's Avatar
W205 C300
The cluster got zapped...
Go here
Old Apr 15, 2006 | 08:58 AM
harryco's Avatar
1999 SLK230
Thanks, I got the dash unit from Ebay and works great!
Thanks again!
One more thing, anyone know where to get a PSE unit?
(99 SLK230)
Old Apr 16, 2006 | 10:28 AM
E-Klasse's Avatar
W205 C300
I have seen them on ebay from time to time. They are not cheep from the dealership. You can check salvage yards as well.
http://cgi.ebay.com/ebaymotors/01-04...QQcmdZViewItem
01 04 MERCEDES SLK230 SLK320 SLK32 VACUUM PUMP
