SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Ignition / spark plug wires
Old Aug 15, 2006 | 04:00 PM
DesignoSLK's Avatar
'07 SL55 AMG, '00/'04 SLK230 Designo Copper, '18 GMC Acadia Denali AWD
Angry Ignition / spark plug wires
Someone please enlighten me. I've searched this and other forums for information regarding ignition wires. To which I see nothing. I'd like to replace them. When I look for them online I only see 2 variations: A 2 cable German (OEM) set and a 4 cable Beru (OEM) set. Am I missing something?!? Who in their right mind would want to only replace the #1 & #3 ignition wires? Anyway...who/what is Beru? Am I stuck going to the dealer for such a simple item? It seems like all the online parts stores get their parts from the same places.
Thanks for any info.
Kevin
Old Aug 16, 2006 | 03:03 AM
Clk&Slk's Avatar
06' Clk 500 Cabriolet, 01' CL 55, 00' Clk 430
The wire are under the red cover.
Old Aug 16, 2006 | 10:39 AM
DesignoSLK's Avatar
Hmm...thanks?
Old Aug 16, 2006 | 08:50 PM
DickB's Avatar
'99 SLK 230
On the 4-cylinder engine there are two ignition coils which each fire two spark plugs. The coil attaches directly to one plug, and a high-voltage wire runs from the coil to the 2nd plug. You only need two high-voltage wires.
Why do you want to replace them?
Old Aug 17, 2006 | 01:47 PM
DesignoSLK's Avatar
OK, that makes more sense.
The car has 84K miles. I bought it with 74K. I've never replaced them and I don't know if the previous owner(s) have either. I guess it's just preventative maintenance. Is there someway to determine if I even need to?
Thanks!
Kevin
Old Aug 17, 2006 | 11:13 PM
DickB's Avatar
'99 SLK 230
You could inspect them for cracks and/or use a tester at an auto store perhaps. They are not scheduled maintenance item. I'm on 83K and I'm not replacing mine.
Old Aug 18, 2006 | 08:46 AM
DesignoSLK's Avatar
Thanks DickB...any idea what the ohm value should be on these? That's easy enough for me to check in the garage.
Old Aug 24, 2006 | 04:17 PM
OJwerks's Avatar
not stock.
If you want to replace, you could consider a wire and spark upgrade.
I did it on my 320 and made a very nice difference..... Magnacor wires and IRIDIUM IK16 plugs...
Old Aug 24, 2006 | 04:56 PM
DesignoSLK's Avatar
What was the noticeable difference?
Kevin
Old Aug 26, 2006 | 02:07 PM
page62's Avatar
Kevin
His wallet was lighter, so the car had less mass to haul around. So it went .000001% faster.
Back on topic: Beru wires are considered by many to be superior to Bosch.
Old Aug 27, 2006 | 10:46 AM
OJwerks's Avatar
not stock.
actually we monitered it with my friends software and there was a reduce in throttle input by 7%... not to mention that the noticable "rough idle" on 320s has significantly reduced..... AND, I did save alot of money, and my red wired give a "motorsport" look to my engine bay... and if you wanna measure by "but dyno"...I can say that the car DOES pull harder to redline than before..... dosnt "die" right before the red line like before.
a s s wipe.
