SLK/R170: INFO: Which Brembo Kits fit the R170?
Lately there is a lot of talk on the forums about Brembo kits, what fits each specific model, how much it costs, etc.
As your top source for Brembo, we wanted to post up the kits that fit your car, and give you guys some links to our website, so that you can see what your pricing options are.
The kits that fit your Mercedes R170 are as follows:
332mm 2PC 4 Piston Front
355mm 4 Piston Front
These kits are all optimized and designed by Brembo Engineers to decrease unsprung weight, reduce brake fade, and decrease stopping distance by 20-30 Percent when used with the proper tires. These braking systems are perfect for use on and off the track!
For more information:
-Visit www.JleviSW.com by clicking the links above
-Call our toll free number, 1.888.JLEVISW
-Email sales@jlevisw.com
-Send an IM to "Jlevi SW" or "Nick at JSW"
Thanks for reading!
JL
Aaron Lephart
That kind of goes counter to pretty much everthing I've ever been told, or learned...........
That goes against everything i've been told over the last 14 years. But then again i'm sure wheel bearings have come a long way since then (laugh).
Aaron Lephart
Will it cause the wheel bearing to wear out sooner than it would normally - I'm sure. On that note, I apologize that I answered your question incorrectly.
What I intended to convey was that yes, it will wear the bearings out sooner, but no, it shouldn't be a serious issue or concern, as people commonly create the exact same effect by purchasing wheels with different offsets than their car is designed for. This may make the wheel bearing wear out a year or two sooner than it would have, but this may or may not be a concern to you.
As for altering steering geometry, I don't know enough about this to comment.
Again, I apologize for accidentally posting somewhat false information!
JL
