SLK/R170: Long term reliabilty of the SLK230K engine and drivetrain?
I'm curious what I might expect over the long haul.
What breaks on these car (SLK?) other than the power tops.
Since the coupe is such a new model, I figured I'd surf over here
to see if I can find anything.
So far, 1 year and it's been no problems, other than an initial alignment issue.
Does the 2.3 liter motor have any notorious issues that have come up in this forum?
I don't spend much time in this forum so forgive me, if these notorious issues are common knowledge among SLK230K owners.
So far in the W203 forum, I haven't seen much, with the coupe being so new, other than a lot of complaints about the 6 speed tranny which I don't have.
Your contructive comments are appreciated, on any issues that might cross over to the coupe, especially from those with close to
100K miles or more, since thats the maximum length of the warranties.
Any blown head gaskets?
Wouldn't look forward to being a ginny pig for the new 1.8 L
engine they're putting out now. Who knows? Maybe it'll be fine.
But part of the attraction of the c230 coupe was that the engine had been in service for quite some time in other models, and of course the value in the c coupe is really tremendous.
I just went for the 6 year 100K mile warranty (maybe I didn't need it?) and really like this car, and plan to drive it at least 100K miles.
I've just recieved a set of C class AMG swaybars, which amazingly only cost ~170 front and rear direct from MBZ, and I'm replacing the springs, tighten up the suspension, then TRUE love will blossom. :-)
I'd love to hear more stories from owners out there.
What about all other "systems" in the car. Just as relaible as the drivetrain?
I've also heard of some drivability problems due to sensors, but that's not really an engine issue.
Other than that, the 2.3L Kompressor engine seems to be just about bulletproof.
As far as other systems, you're much more likely to have issues with the transmission (manual or automatic), than the engine.
I don't want to scare you, but I think you can expect a few electrical gremlins.
The usual problems I seen were:
1.car just dies randomly after long drives the k40 relay in the fuse box on pass. side near windshield shorts out
2.switch over valve goes bad. car feels like its very weak. right on airbox
3.usually the mis-steps of the top operation can be number of problems. most I seen not wanting to come out of the a-pillar (close it back take cover off make adjustment to release pressure due to unserviced pins)
4.cd changer not working do to bad gutter design which is a tsb/recall can't remember exactly. on right rear or car.
not really much to list considering it's a mercedes
Congrats on purchasing this car I'm sure you wife is very happy.
That sound my friend is normal i'm alfraid
we call this engine the (typewriter) very clattery!
I'm damn close to 177K miles!
I have my mileage award from MB and everything.
Yes, the M111 is a great engin
Everything else after it is just crap!
M271, junk! M272 have the freakin balance shaft problem,
all after the Chrysler takeover.
I replaced the supercharger at 120K in advance of it's failure, bought the new one
for 600 off ebay sold the old one for 250.
Better than waiting for it to fail and paying 2 grand.
Rebuilt the alternator too at the same time, 200.
Recently had the starter brushes replaced 20 buck!
+ a pain in the *** remove and install.
Other than the occasional blown coil pack pretty much fine.
Only thing I had to pay a mechanic for was diagnosing which
wheel sensor went bad once.
I just flushed my tranny for the 2nd time, and
replaced a coil pack on #1 and cleaned and sealed the MAF.
Yes, sealed. On my car, it doesn't appear to have any kind of seal.
I use some duct tape, and a large oring to keep the pressure up.
Runs perfect still but I do have the dreaded leaking #4 cylinder spewing coolant down the side of the block just a little, have to top it up every once in a while.
I have all the stuff to fix it, but no place to do it after Sept 30 so, and I'm still looking for a new place to live.
oh well. Like I said runs great!
New front brake pads (AMG C32 4 piston) are immanent, already have pads and rotors.
Wow 177k. amazing. i own the same model. 2002 C230 with the 2.3L engine. i was thinking i should have looked for the 1.8L 2003 and up. but seeing this post looks like i made the right choice.
OT: what was wrong with the M271s? i know the M272s are the V6 in the C320 coupe right? what were the issues of the M271 engines?
The only repairs I have had to do:
A/C fan at about 160k.
Rack and pinion at 181k.
Oil cooler gasket at 225k
A/C compressor at 227k.
There have definitely been lots of problems after the M111, but Mercedes gave us one of the best diesels (the OM648), years after the M111. It's arguably the most reliable. The OM606 is a great engine, but had its problems. The M112/M113 are really good engines. The M113K is arguably the most reliable V8 AMG and that was after the M111.
It now has 256K miles. It has taken a plethora of parts over the years to keep it going.
I've had a leaking head gasket on #4 cylinder like most M111 since 150K miles, but I just keep topping up the fluid level and driving it.
At this point, I'll probably have some corrosion on the head if and when I ever get around to pulling it.
It sat for a while but in the last year or so,new NOS MAF, new tires, starter, alternator, supercharger, shift module,
refinshed steering wheel, recharge AC and new front brake pads and rotors (AMG). At around 200K I did the
fuel filter, water pump. So running well at this point, and hard to want to tear the engine apart when it's running nice and smooth
