SLK/R170: Kleemann Boost Kit
SLK230
![Angry](https://mbworld.org/forums/images/icons/icon8.gif)
On my SLK230 from 98 I have mounted a Kleemann Bost Kit ( 2.3 ? ). The SLK is with aut. trans. When I start the car in the morning, and its cold outside ( 3 deg. C ) the kompressor is activated from the start, and because of this, the transmission won't shift. After 2 approx. 2 min. the problem disappear. Anyone have the same prob. ???
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
1 Post
'02 SLK32 AMG
It won't shift at all?
It really doesn't sound like a problem with your boost kit. The kompressor is supposed to engage when it's cold to help the engine warm up faster and reduce exhaust emissions. Also the transmission is supposed to have higher shift points when it's cold for the same reason.
I really don't know what the problem is. Could be an electronics problem, could be low transmission fluid. Have you tried switching the "W/S" switch for the transmission?
Hr. Knudsen
Jeg kan forsikre dig om at dette problem intet har med dit KLEEMANN boost kit at gøre. Boost kittet får kun kompressoren til at "snurre" lidt hurtigere rundt, så der kommer mere effekt når du laster motoren. Tomgang og dellast har kittet ingen effekt på noget som helst, hvis det havde været kittet så havde du haft problemer med fuld last.
Det problem du garanteret har, er når motoren / gearkassen er helt kold og du køre med let speeder, så føles det som om den bliver hængende i gearet og du faktisk må provokerer speeder pedalen lidt op og ned for at få den til at skifte ???????
Når gearkassen er varm er der ingen problemer.
Hvis du kan nikke genkendende til oven stående, så besøg en gearkasse expert, f.eks. Mr. transmition i Lyngby.
SLK230
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
Well it shift after 1-2 min when the engine get worm. I have not tried the S/W switch, but I will try it tomorrow. I have tried to disconnect the kompressor before I start, and then the aut. trans. work fine !!
Re: Kleemann Boost Kit
I suspect that in warmer weather you will not have this problem, it has nothing to do with the kompressor or boost kit
Mabye I am funny, but I tried to ask you something and you ignored me, but I could get your attention.
KLEEMANN have just explained you why it's dooing that, it's normal and programmed in the cold start cyclus of the ECU/EGS.
If it's very bad, then I would ask an experts advise.
