SLK/R170: 2002 SLK 320 Broke down... HELP!
Later,
Patrick
According to my bud at MB corporate, the tech from MB do not recommend slk owners to go thru a car wash due to the high pressure spray that may tear the seal and cause leakage as the car ages. I was also advised not to spray strong water directly to the seal area. I dunno whether this is completely true or not but I just want everyone to be aware.
You didn't say whether your father washed the engine compartment, but it's not a good idea. I used a pressure washer on the engine in my former '99 SLK and fried the heater control valve.
It cost me $750 to replace it. It is a known issue.
Mine had the same symptoms
it ended up that the gasoline that he put in was more than half water. Of course, Amoco said that they ran out of gas and bought some from Sonoco. I believe it.
It ended up only being from the premium pump.
