SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Brembo/MB four piston caliper anyone?
Old Jan 6, 2011 | 02:13 PM
LantanaML320's Avatar
2004 Chrysler Crossfire
I have a set of four piston Brembo calipers for sale. These would be a bolt on swap and requires C350 Sport rotors which are 330mm diameter and 28mm thick. In the R170 You have to swap sides but otherwise it is a bolt on swap. You may hear people tell you that the becuase of the staggered size pistons you can't swap sides. I have a similar set up on my Crossfire and swaping sides doesn't matter. It is thought that the staggered size pistons are to promote even pad wear, but many of us Crossfire owners have done this and seen to negative issues. Info on the calipers can be found here.
https://mbworld.org/forums/c-class-w...de-anyone.html
