Brembo Brake upgrade anyone?
1 Post
2004 Chrysler Crossfire
I have a set of four piston Brembo Calipers that are a direct bolt on for C/SLK/CLK/Crossfire. They will fit a 330mm that is 28mm thick (C350 Sport). They are natural gray with white "Mercedes Benz" lettering. These can be painted silver (or any color) and AMG/Mercedes Benz/Brembo lettering is available on Ebay. I bought these from a guy that said they were CLK500 which uses a 345mm rotor but he was wrong. I was hoping to upgrade to 345 becuase I am doing a 330mm SLK55 rear rotor setup and want the front rotors to be larger than the rear. SLK32 rotors will not work with these as SLK32 uses a 32mm thick rotor.
1 Post
I have a similar set up on my car. I bead blasted mine and then painted them AMG silver. I then added the AMG lettering for the C32/C55 look. This is a great upgrade for any car that has smaller brakes or who has the ugly floating calipers. Also changing pads is very easy with these fixed calipers. I have listed them on Ebay for a slighly lower price of $220 shipped. I would really like to see these gone soon as I just bought another set of calipers to go to 345mm on the front of my car. I am doing this because I am working on a 330mm rear brake set up and want my fronts to be larger than my rears.
1 Post
Yes it is a a very fun monster. You cannot adapt a V6 ECU to a V8. The V6 ECU looks the same but is missing drivers for the extra coils and injectors of a V8. I programed the donor V8 ECU to my car. It took me two years to figure out how to do this. but the approach i took makes MB engine swaps very doable. There is guy on the Crossfire forum using this approach to put 55 Kompressor engines into Crossfires and other MB cars. A Crossfire/R170/SLK with a 55K is the ultimate monster and will blows the doors off of a SLK55 and just about anything else MB makes. the power to weight ratio is amazing.
1 Post
"annoyance" and "self-righteousness", amoung others...
Is there someplace to read up on this approach to tuning the appropriate ecu for MB engine swaps? Any mention of engine swaps around these parts arent even mentioned as automatic replies regarding the near impossibility of getting the tuning down.
1 Post
Here is the ultimate monster 55K Crossfire:
![](http://i861.photobucket.com/albums/ab172/Rlantana/Rudy-2.jpg)
1 Post
Here is a thread that shows you what can be done with these calipers...been there, done that.
SLK 350 Calipers rebirth
2013 ML350
Hope you are well. Ill hit ya with a PM.
Latana...IMPRESSIVE WORK !
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Hope someone grabs these calipers. it is a great/easy upgrade.
1 Post
The programing is slightly easier in a SLK R170 because it you don't have to get the donor ECU to accept a Chrysler Vin number which I managed to do but wasn't fun. Imagine a R170 SLK with a supercharged 55! Not many MB's would be able to keep up with it. The power to weight ratio would be hard to beat.
