car died during idle. After waiting 5 min, it started ok, but power is very shy. check engine light on. Scanner says crank position sensor...I found lot of infor on CPS replacement on this forum, but not on SLK320 (very strange, no one has a problem with CPS on SLK320?). Read through other threads for the removal/installation, no problem. I looked at the engine/tranx area by the firewall, and can't find this CPS.
Could someone tell me where or some picturs would be great.
thanks
d
thanks
d
got it thanks. did not realize that the top plastic cover needs to be removed. Instersting enought, I found more details infor on the Crossfire link,
http://www.crossfireforum.org/forum/...on-sensor.html
again thank you
d
again thank you
d
It has been two weeks, since the cps is replaced. Car is running fine now. Yes I had to remove the bracket for easy access. Getting the cable clip is troublesome. I found that it is easier to remove the sensor with the cable installed, and then remove the cable. It is just me. Thanks for all the infor
d
d
thanks
d
I haven't seen many posts for the slk320....Anyone on the forums with an slk320 have this kind of problem? It's kind of unnerving seeing how I just bought this car not too long ago; was wondering if this is something that is common and needs attention..Originally Posted by dbuckius
car died during idle. After waiting 5 min, it started ok, but power is very shy. check engine light on. Scanner says crank position sensor...I found lot of infor on CPS replacement on this forum, but not on SLK320 (very strange, no one has a problem with CPS on SLK320?). Read through other threads for the removal/installation, no problem. I looked at the engine/tranx area by the firewall, and can't find this CPS.Could someone tell me where or some picturs would be great.
thanks
d
Did any electronic work need to be reset? My dad want to change this himself but is worried if anything needs to be reset electronically.
My car has done the same thing. when hot cranks but won't start til it cools, usually about 30 minutes after.
2001 SLK 320
2001 SLK 320
No need to reset anything. Car is still fine
[QUOTE=dbuckius;4815237]It has been two weeks, since the cps is replaced. Car is running fine now. Yes I had to remove the bracket for easy access. Getting the cable clip is troublesome. I found that it is easier to remove the sensor with the cable installed, and then remove the cable. It is just me. Thanks for all the infor
I like to thank you guy's at MBWorld for the good information you gave.
ExploreJunior Member
Quote:
d
Good point dbuckius, I broke the connector when pull it off from the sensor on my E320 4 years ago.Originally Posted by dbuckius
... I found that it is easier to remove the sensor with the cable installed, and then remove the cable. It is just me...d
I have a 1999 Oldsmobile Intrigue GX with a 3.5 L engine and when I try to crank it it would try to turn over and eventually would! Sometimes while I'm driving it will try to cut off and sometimes it will cut of when I'm driving it! This morning it will not start at all tries to turn over but will not crank at all! Can someone please tell me what to do to fix this problem!
2001 SLK 320
Had a problem with my slk 230 not starting today. It's run perfect for 3 years apart from replacing the air flow meter. It turned out to be the coolant level being too low. Topped it up and it started straight away. Always worth checking it before anything elseOriginally Posted by stephar4
Did any electronic work need to be reset? My dad want to change this himself but is worried if anything needs to be reset electronically. My car has done the same thing. when hot cranks but won't start til it cools, usually about 30 minutes after.
2001 SLK 320
