SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Top wont operate up or down
Old Jan 19, 2013 | 01:54 PM
earld's Avatar
2001 E430, 1999 SLK230
Just finished installing the front latch cylinder on my 99slk. It took me about a week since the monsoon rains had me unable to work on it. But now its in and all lines hooked up . But it wont work. No power to the pump. The red light in the switch is on and flashing ,but it wont work. The car was covered because I had the top open so I could fix the cylinder. But ther is some dampness inside the cockpit. I think that due to the tons of rain the dampness is causing an issue. The car starts and runs fine . Its just that when you push the switch to close it or open it the top wont move. Everything works on the car. radio,headlights,turnsignals, AC,heat. Just the pump wont operate. So I may have unplugged someything when I took cylinder out I forgot it. But I ahve been unable to find any loose connection.So if you can guide me to a possible cause I will greatly appreciate it..
Old Jan 19, 2013 | 05:34 PM
leapyfish's Avatar
2012 E350 75,xxx miles, 1998 SLK230 250,xxx miles
Have a look at the link to the Vario Roof Troubleshooting Guide in my signature,
it may be something as easy as a sticky switch.
Old Feb 6, 2013 | 01:45 AM
MyBigBenz's Avatar
SLK
Is there a documented procedure to manually lower and raise the convertible top?
Old Feb 6, 2013 | 01:58 AM
leapyfish's Avatar
There is a way to manually raise the top in the owners manual.
