SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Reverse lights come on then go out
Old Aug 3, 2016 | 04:53 PM
machisono's Avatar
r170
Hi folks, Hope you can help me with this issue.
I have a 1999 SLK 230 with 53K miles on her. For the past 6 months my left reverse light would go out and I would get a notice on the dash that a light is out. I would then open the trunk and turn the bulb housing a little (I previously changed the bulb) and the light would then function for a few weeks then I would go through the process again. Now both lights will function when I put her in reverse and then both would immediately go out.
I have already changed out the bulbs. Can you offer some suggestions where I should examine next. Is there a switch that needs replacing?
Thank you
Joe
Old Sep 1, 2016 | 06:54 AM
El_Toro_33809's Avatar
2003 SL55; 2001 SLK320; 2005 C240
If you get them to work be jiggling with the bulb, it sounds like there is a loose connection in that area. If there is a problem with the switch, that is located in the shifter housing.
Tim
