SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Twin Spark V8
Old Dec 17, 2018 | 12:03 PM
Toolatenow's Avatar
2001 SLK 320 and a 2011 C 350
Twin Spark V8
I have a twin spark V8 engine. But the plats on my door seals say V6. Ya think one or the other was changed at some point? My pride and joy is a 2001 SLK 320, I call em Lil' Man!
Old Jan 1, 2019 | 07:41 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
You can verify what it originally came with via the vin #.
Old Jan 2, 2019 | 10:33 AM
loggato's Avatar
1999 SLK 5.5L 6-speed, 1993 300 SE
Can you take a picture of the engine bay for us?
The biggest engine in an R170 is the 3.2L V6 AMG engine. no V8's.
except mine, which I swapped a V8 into - I can tell you that you cant just swap the engines without anyone knowing about it!
Old Jan 2, 2019 | 11:10 AM
Toolatenow's Avatar
Thanks for the answer, I should have known that much. But I'm learning. And my mechanic says it is a V6. So they replaced 12 Units of spark plugs and an Ignition wire set. I still need to learn the difference between twin and dual plugs systems. I feel certain I have the lesser of the two, as its just a stock not specially built for racing. But he can surly get up and go!
Old Jan 2, 2019 | 12:18 PM
loggato's Avatar
Simply put it has 2 spark plugs per cylinder. (Alfa Romeo called theirs "TwinSpark"). I believe it is this way for cleaner burn and better emissions, but If it was remarkable in any way, many other engines would be using the technology, but I believe the results are negligible and most manufactures found that one plug was more than enough.
