SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: 6 Speed Transmission Oil
Old May 21, 2020 | 07:17 PM
Biohazard's Avatar
2004 SLK 320
Question 6 Speed Transmission Oil
Hi everyone. I recently picked up a 2004 manual SLK 320. I want to change the transmission oil, as well as the differential oil. What products work best for each?
Has anyone had issues with Liqui Moly LM2048 75W90 Fully Synthetic Gear Oil? Can I reasonably use it in both the transmission and the differential?
What other things should I look out for?
Old May 22, 2020 | 01:59 PM
Gazwould's Avatar
S204 C250 CDI Sport
75W-90 is quite thick .
Old May 22, 2020 | 02:30 PM
Biohazard's Avatar
2004 SLK 320
Yes, but I thought the OE transmission oil was 75W-80? That's what I come up with when I search online. So would 75W-90 synthetic be any different?
Old May 23, 2020 | 03:37 AM
Gazwould's Avatar
S204 C250 CDI Sport
Yes despite the same 75W the cold viscosity will be a big difference .
This can effect the smoothness of the early gears when cold .
Old May 26, 2020 | 01:28 PM
Biohazard's Avatar
2004 SLK 320
That is part of the reason why I want to do a transmission oil change. It is almost impossible to get the car into 1st gear, even when at a dead stop. Second gear also has to be forced in, and it never goes in smoothly. If the car is moving even 2 mph, forget about 1st gear, it will never go in. Has nobody experienced this before?
Old May 26, 2020 | 04:52 PM
Gazwould's Avatar
S204 C250 CDI Sport
Originally Posted by Plutoe
Go to any dealer and ask for their recommendation. Then shop the oil
Dealers don't always have the best answers , get the manufacturer spec number and see how the specialist oil producers version compares .
