SLK/R170: secondary air system p0410
Then I replace the check valve the code went away and never returned, my part was about 60 bucks.
This is the closest view I can find of the valve I changed I also took off the other valve in the line going over to the throttle body and I cleaned it inside they get dirt and moisture in them then the vaccum can't operate the valve inside clean yours out if you have one on your 320
In this pic its showing the valve they changed my car is set up like this one in the pic the goldish color valve with the red line, shows the location on my car.
https://www.benzworld.org/attachment...-60-jpg.98151/
I checked at the mercedes benze parts store it shows the air system for your car it doesn't have the same valve like my car.(hehttps://www.mbonlineparts.com/oem-parts/mercedes-benz-a-i-r-pump-0001403785?c=bD0xJm49U2VhcmNoIFJlc3VsdHMmYT1tZXJjZ WRlcy1iZW56Jm89c2xrMzIwJnk9MjAwNCZ0PWJhc2UmZT0zLTJ sLXY2LWdhcw%3D%3Dre is the page with the diagram and the parts in the system (
What you need to do find is the flow chart for checking out the 320's secondary air system, then go step by step until you can find the problem of the system that causes the light.
Otherwise you are going to be throwing parts at the car to get the light to go out, my car worked fine with the light on if your car works decent like mine did you really don't need to make the repair.
I sell the cars I drive if I had no intention of selling it I would have driven my car the way it was, but since I gave my electric car back to GM I made the 230 my daily driver until I can buy another Bolt.
Hope you find the problem.
There is always a way to get around it.
I would check around for the part number,when you get the part number, you can search just for the part number, instead of searching a general term like secondary air valve.
I buy some of my parts at Autohaus AZ they have OEM and aftermarket parts when they are available.
Here is the part I think you mean for 120, but you would know better when you see the piece.
https://www.autohausaz.com/pn/MB-0021403560
The only thing you can do is eliminate each item that can causes the code, on my car it was only the valve that worked by vacuum, or the larger check valve.
I cleaned and checked the vacuum valve, I pulled a vacuum on the valve by sucking on the hose I could see the valve try to move that meant it was working, while I had it off I cleaned it because it was sorta dirty inside.
There has to be a way of checking that valve, take it off and clean it, maybe you will see something wrong along the way, like a stuck valve stopping it from working.
Good luck
The other valve that is vacuum operated was just dirty I cleaned it and checked it worked then put it back on the car.
I bought my car almost 3 years ago, it had a few problems when I bought it but it ran great and it only had 75K on it, I paid $5K for it tax and all.
The most expensive repair was a new radiator it cost me a little over a 100 for it, I changed it because they car overheated with the air on since replacing the radiator I have no heating problems in 100 degree weather.
Right now all I do is keep my car clean and change the oil every 3500 miles, I changed all the fluids serviced the transmission right after I bought it, just dropped the fluid in it again I plan on keeping the transmission nice and clean inside.
Someday I will buy another one, if I can buy a low mile car, I just saw a low mile SLK for 8K on ebay today, it needs a door and a fender otherwise the car is nice if I just didn't spend money on building a jeep with a plow I would have bought it.
I love my SLK, when you get yours right you will love yours.
I do love my SLK even with this annoying trouble and the BAS ESP business. In a picture up above, you show a red arrow going to a thing that cannot be dismantled and I wonder if that is part of EGR which is separate from this secondary air business as far as I know. You have been a great help to me on this. Thank you.
I think the valve shown for your engine has 2 parts inside, the vacuum valve and the check valve, are in that one part, where my car had 2 separate parts your car has one piece deal with the both parts in it.
You should check around the net for the test procedure for the code set for your model for the code set.
The test procedure should walk you through the steps to check and evaluate the parts in the system.
Then you can zero in on the part that failed instead of wasting money buying things you don't need to get at this time.
For my car the procedure was to check the vacuum valve, make sure the valve moved when I applied suction, clean the valve and put it back on.
Then it said if the car put the check engine light on again the problem was in the check valve the part I changed.
When I changed the check valve my car stopped throwing the same code your car is throwing.
I must have cleared the codes 50 times with the same result, hoping it was a faulty code then within a day the check engine light would come back on.
I know its frustrating but you need to follow the procedure for your year and engine type to get anywhere with this code.
For 12 bucks these are worth having if you own a Benz prouduct these bolts are all over the car so some day you will need them again.
I bought a few check valves that have 3/8" barbed ends, a 3/8 fuel hose is tough to push on it with clamps it would never come off.
What I have are check valves that go in line they are made of aluminum I think, or some type of light metal.
Mine are something like this got them on ebay.https://www.ebay.com/itm/40296275539...3ABFBM0rT126hf
