SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Mirror turning yellow
Old Nov 29, 2004 | 08:16 PM
pfphipps's Avatar
2003 E320
99 SLK230--had it since new. The driver's rear view mirror has turned yellow. It started out looking like the other mirrors but in the past few months, it has turned yellow and seems to be getting worse. Anyone else have this problem?
Old Nov 30, 2004 | 02:22 AM
maninblack's Avatar
1999 210 4matic / 2011 W204 C300 sport
not on mercedes , but for bmw , it the element for the heated mirror turns bad , maybe the same
Old Nov 30, 2004 | 05:48 PM
pfphipps's Avatar
2003 E320
Interesting. I will check that as well. I never really saw the big advantage of the dimming mirror especially since the right hand size does not have it anyway. Maybe my eyes are not that sensitive any more.
Old Dec 21, 2004 | 09:58 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
It sounds like the dimming part of your mirror has failed. This is usually due to an electrical problem... so if you replace the mirror glass, you may end up with the same effect.
-s-
Old Dec 21, 2004 | 10:05 PM
DickB's Avatar
'99 SLK 230
Can't imagine what kind of electrical problem would cause this; it's a simple heater in there. My mirror turned blochy yellow and replacement of the glass with its integrated heater was the answer. No problems after many months. I think it's the glass and replacement is the cure.
Old Dec 22, 2004 | 03:28 AM
scorchie's Avatar
I'm glad it worked out for you, but your single case does not constitute a good sample set.
It's not just a simple heater in there, there's a liquid crystal for use with the autodimming system. Sometimes the electrolyte is contaminated; other times overcurrent to the autodimming can cause yellowness. The overcurrent is what you want to beware of.
The heater may cause a problem, but I've seen W210 mirrors get REALLY HOT without causing any problems. I've seen nearly as many mirrors get ruined because of overcurrent to the autodimming (Steve does a lot of experimenting for research purposes).
-s-
Old Dec 22, 2004 | 07:40 PM
pfphipps's Avatar
2003 E320
What causes the over current problem? Will it correct itself if the heating is disconnected? Here in New Mexico, I have not seen much of a need for heating the mirror anyway.
I see what appears to be a sensor in the corner of the inside mirror but where is the electronics that controls the outside mirror dimming and heating? Any good words on troubleshooting, any electrial diagrams or hints on what can and cannot be repaired would be appreciated.
At first I thought it was in full dim mode but I notice at night when the regular rear view mirror inside the car dims, the outside mirror is very yellow compared to the view in inside mirror.
Old Dec 23, 2004 | 12:17 AM
DickB's Avatar
'99 SLK 230
I stand corrected.
I had assumed that a heating element of some kind was used to dim the mirror. I think I was wrong. Investigating more closely I find that the mirror has both a heating element to clear ice and snow (triggered by a thermo sensor in the mirror) and a voltage control for dimming the mirror (not sure of the mechanism – LCD?). The nominal dimming voltage is 0-1.5 volts. If the control circuitry malfunctioned and fed a higher voltage to the mirror, that could cause an over current situation.
Old Dec 23, 2004 | 12:29 AM
DickB's Avatar
'99 SLK 230
I see what appears to be a sensor in the corner of the inside mirror but where is the electronics that controls the outside mirror dimming and heating? Any good words on troubleshooting, any electrical diagrams or hints on what can and cannot be repaired would be appreciated.
Now that I've studied info from alldatadiy.com, here is what I think I know:
The sensor in the outside mirror is a temperature sensor for the heating element to clear ice and snow. it is activated at 15 degrees C and deactivated at 25 degrees C.
Dimming is controlled by the inside mirror, which sends a voltage signal of 0-1.5 volts to the left outside mirror.
I'd still bet that if you're seeing yellow in the theoutside mirror the problem is with the mirror.
Old Dec 23, 2004 | 11:27 AM
pfphipps's Avatar
2003 E320
More information than I have ever had before! Does anyone know the procedure for taking the outside mirror apart? This seems to give a C class mirror information but is it the same for the E?
https://mbworld.org/forums/showthrea...or+replacement
As far as the mirror heating, 15 C seems high for where it comes one but maybe I do not understand that part living where the humidity is sometimes under 5%. On the other hand, 15 F would seem way too low.
Old Dec 25, 2004 | 08:47 AM
DickB's Avatar
'99 SLK 230
1 Fold the outside mirror forward
2 Tip the top edge of the mirror glass to the outside
3 Using a screwdriver, push the retaining spring (1) upward and remove the mirror glass from the drive
4 Disconnect connector (2)
5 Install in the reverse order
