SLK/R171: SLK350 with 18" RIMS
Does anyone have the SLK 350 with 18" rims? I was hoping you guys could answer a few questions for me?
1. Are there any problems?
2. Does it scratch/rub against the car?
3. Did you have to lower the car?
4. How is the ride?
5. Is it staggard?
6. What exact size gets the best fit?
Thanks everybody, I really appriciate it.
4. How is the ride?
5. Is it staggard?
As long as you get the right offset, I don't see there will be any scratch and rubbing problem, cuz SLK55 has stock 18". Depending if you have sport suspension or base suspension, I don't see lowering is a must with Sport.
#5, 6
I believe you can use 225/40-18 and 255/35-18 tires
So you think that I will need to lower the SLK in order for the 18s to look right? I do not have the AMG Sports package? Does anyone have 18s on the SLK350 without the sports package and did not lower the car? If you do, I'd really appriciate it if you could post some pictures!
dinko
dsb
danamg
zaint10
if you get the right offset, it should not be too much, the rear tucks in the fender when you hit a pothole, so there should be no damage.
https://mbworld.org/forums/classifieds/140290-fs-slk55-18-18-spoke-rims-tires.html
-Matt
