SLK/R171: what rpm should I change gear?
06 SLK350 AMG SPORT PACKAGE
I just got my new SLK 350 with manual transmission, i haven't taken any pictures, Iridium Silver with the Sport Package, very nice
question:
1. at what what rpm should I change gear?
thank you very much
question:
thank you very much
'09 E93 335i
depends on what you're trying to do - if you're just normal driving (not racing), you can shift almost anywhere you want between about 2500 - 4000 RPM. If you're racing, you'll want to take it up to redline (I don't know what that is on an SLK350 - I'm gonna guess about 6000) but I wouldn't go above redline with a stock engine/drivetrain setup.
MBZ SLK
For everyday driving, I usually shift before 3,000 rpm, plenty of torque and fast enough for the road. I usually bypass fourth gear and go from 3rd to 5th, it's becoming a habit, don't know if it's good or bad but I'm getting 26mpg in the city.
Congrat's on your purchase, and enjoy your ride.
SLK55 AMG, BMW X5 3.0d Sport
You need to take it just short of the redline before upshift. Around the 6100 rpm mark. Ignore duo comments, how many race drivers do you see short shifting unless they are winnning the race and in "cruise" mode
SLK55///AMG The MONSTER on the block
Originally Posted by Sharp911
What about when comming to a stop do you down shift threw all the gear or drop it to neutral?
Another comment regarding Ynots opinion...... if the fastest way to progress is as you say to change up early and not at the redline why does the 7G Sport program shift at the redline? peak power also plays a role in how quickly you progress so shifting early actually drops you to a place in the rev band (in the next gear up) that has lower power than if you waited and shifted closer to the redline.
a quarter mile at a time
Originally Posted by Ynot
Actually, b/c the max torque range is between 2,400 -5,000 rpm, you don't want to wait until close to redline to shift b/c when you get pass redline, the engine shuts off and really slow things down. I find shifting at 5,000-5,500 is optimum, in the max torque band and will yield the fastest times.
To get the quickest acceleration, shift as late as possible in each gear.
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
Originally Posted by Easy-SLK
FFS get an auto, its obvious you don't know how to drive. I think you are at the same level as YNOT ![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
slk 350
And the little stars weren't stars when I typed them.
slk 350
Originally Posted by bmwnomore
I have the six speed manual and downshift all the time. Depending on the speed, usually downshift through two gears like from third to second. Slows down the car without using the brakes too much.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
MBZ SLK
Originally Posted by e1000
the reason this dosen't work is that once you shift, you land yourself in a taller gear, therefore reducing the amount of torque multiplication through the gears.
Originally Posted by SLK55AMG
A racing driver! ![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Originally Posted by mick1
alrighty. I am going to exit the freeway, so I am going to downshift from 6th gear to 5th to 4th to 3rd to 2nd .... NOT ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
You asked who would downshift through the box....... the answer is a racing driver. Are you a racing driver? I'm not but that doesn't stop me heel toeing down the box when driving hard.
I seriously doubt any respectable racing driver would downshift through all the gears to stop a car. He might downshift from 4th to 3rd when going through a corner but downshifting from 6th to 5th to 4th to 3rd to 2nd to 1st to stop the car is silly, to me. However, people can drive like that if they choose to do so.
Here's Sharp911's original question:
I think you mis-read my response to the question originally posed by Sharp911
However many (not all) racing drivers with normal manual shifts will usually downshift though the box as it puts less strain on the transmission and is smoother than skipping gears....... I could be totally wrong (I'm sure somebody will correct me if so) but I think this is even more important in race cars without synchromesh.
I agree, if you time it right, shift before redline everytime will yield the fastest times. I didn't make myself clear, assuming you are racing someone to 60mph, I've notice trying to time your shift before redline is difficult and if you miss it, the engine stops for a second, it's much easier to shift a little before redline. Maybe I need more practice
A lot of people misinterpret torque curves and think they should land each gear in the meat of the torque band. The problem is, torque is multiplied by your gearbox. As soon as you grab a taller gear, you will be dropping much more torque than you would if you stayed in a shorter gear.
'05 A4 1.8TQM6
I'd imagine when slowing down at a red light or stop sign, downshifting thru all the gears before stopping is much more wear on the clutch than using brakes. Brakes are much cheaper to replace than a clutch, imo.
SLK 55 AMG
If your trying to keep the car perfectly balanced you would use as many gears as you can. using the clutch to slow you down is engine braking a balance between engine braking and brakes is much smooth way to slow and the car is much better setup already in gear as you want to ease the brake and apply power. It's much more noticable on a sportsbike where the lowest revs you hot when racing it are 8k. not to upset the bike you want to be in gear as much as possible. and the faster more responsive cars are the same applies. check out the new gear duel clutch gear boxes. freecoasting or slowing down with the clutch disengadge aint a great way of driving.
I'd agree with Ynot if your driving in manual switch early, if the car has that much lb/footage it aint going to matter to much and hitting the limiter is a huge penalty. that's why I drive S mode on the track.
2015 C63S E1 (sold 2012 C63 AMG Sedan (Premium & APX)) & 09 C300 Sport 4Matic
You downshift into the appropriate gear you would need to drive off after braking is done. No need to get into the gears you won't be accelerating under. If you're coming to a complete stop, it's best to put the car in say 2nd (after you have slowed) just in case you would need to accelerate away to avoid a mishap. Under these circumstance you would not even bother to let the clutch up as you come to a complete stop.
I hesitate to use the engine braking under normal conditions (except when descending a hill) as breaks are much less expensive than a clutch job or a miss shift.
The real danger is shifting unknowingly into too low a gear when accelerating. Say you put the car into 2nd instead of 6th from 5th under power and let the clutch out. If you follow through with this maneuver, good by engine if it revs well beyond the safe maximum it was designed for. A common way to destroy an engine for those young Honda street racers.
In any case, downshifting should be used to maintain speed down a grade or to get ready to move off after braking.
..jack
..jack
THANK YOU ALL FOR POSTING,
i have been enjoying my SLK350, going up and down of Highway 1, in CA.
So nice, btw, how do I post pictures?
thanks again
thanks again
