SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: leak from breather on g tronic transmission r171 350 slk
Old Aug 12, 2021 | 07:36 PM
J Gibbs's Avatar
350 slk
Just discovered a leak from the breather on my 350 slk auto transmission. What could possibly cause this. It is copious.
Old Aug 12, 2021 | 08:40 PM
E55Greasemonkey's Avatar
This place is a joke.
Over-filling.
Old Aug 13, 2021 | 06:33 AM
J Gibbs's Avatar
350 slk
Wrong, valve plate cracked across pressure regulating sensor, massive overpressure causing violent oil sprays withing casing hence leak. Substituted used valve plate - complete cure.
You gotta ask yourself how on earth did the valve plate crack?
How did I find it, looked up all the drawings I had of the transmission, only direct access to breather is a machined slot in top of casing. Checked bellhousing for cracks(visible from above), none apparent pulled valve plate etc magnifying glass and bingo there's the crack.
Popped in spare that I just had laying around and job's done.
Old Aug 13, 2021 | 11:37 PM
Wow. I've removed hundreds of valve bodies, even dropped one or two, and never seen one crack. One possibility is a faulty installation where it wasn't sitting flush on the case and the screws were used to force it down. Good job finding the problem !
