SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: Help - question re power seat adjustment
Old Dec 29, 2004 | 05:37 PM
ajoe's Avatar
I have the power seat option. I've always felt that the drivers seatback was in a too upright position for my driving comfort. Someone else on a forum complained that their seatback was rubbing against the back shelf area and causing an abrasion on the seat. I can't get my seatback to come within 6 - 8 inches of the rear shelf regardless of how I try to adjust it. The passenger seat, however, seems to work properly and I can lean the seat back to with a couple of inches of the rear shelf. The question I have is the drivers seat supposed to have this limitation by design or do I have a faulty seat? Any feedback would be appreciated.
Old Dec 29, 2004 | 08:28 PM
RoadkingHI's Avatar
05 SLK 350, 97 S420, 92 Jeep, 04 Kia, 28 Ford Tudor, 51 Ford F3, 01 Harley, 03 Harley
Cool
Mine does the same thing. I noticed that when I try and push it back the lower seat moves forward then after a couple of button pushes I gave up and left it.
I thought it was me not being able to figure out the adjustment but now you got me wondering and will work on finding out an answer.
Old Dec 29, 2004 | 08:38 PM
radiatefunction's Avatar
It does that to prevent you from hitting the back wall.
To move your seat back more (reclining more), lower the seat a little bit then try.
R(f)
Old Dec 29, 2004 | 08:40 PM
bmwnomore's Avatar
slk 350
power seats
My passenger seat does that. The driver seats seems o.k. I was able to get the passenger seat back a bit further and not upright by toggling between the buttons quickly. I wonder if the tolerance can be adjusted by the dealer.
Old Dec 30, 2004 | 09:31 AM
ajoe's Avatar
Thank you for the feedback (more)
Discovered that the ability to lean the seatback back is controlled by the heighth of the seat much more than how far forward the seat is placed. Once I lowered the seat I was able to recline the seatback into a comfortable driving position for me. The only negative is that in the "exit" posistion it now rubs against the back shelf.
