SLK32 AMG (R170) 2001 - 2004: Discuss the SLK32 AMG.
03 Slk 32 amg preformance help?
Old Sep 9, 2011 | 04:20 PM
amgfanatic18's Avatar
03 Slk 32 Amg
I want to increase overall performance on my Slk 32 amg but i dont know what to do... Any suggestions?
Old Sep 9, 2011 | 09:49 PM
320 dreamer's Avatar
2003 porsche 996 turbo
intakes , tune the ecu, add a pulley and all the cooling mods out there. that will get you to 350 rwhp. then start the diff exchange and brake upgrade after that headers and exhaust. tranny mods after that
Old Sep 9, 2011 | 10:57 PM
03 Slk 32 Amg
Could you provide sites or links to get all of this. Cause i really dont know what brands to get this from.
Old Sep 10, 2011 | 07:51 AM
go to crossfireforum.org the srt-6 is the same car under the skin. search for all the modding info in the srt-6 section. needswings and eurocharged will get you into the 11's
Old Sep 10, 2011 | 12:00 PM
03 Slk 32 Amg
Alright thanks so much
Old Sep 10, 2011 | 01:33 PM
im 32krazy! over there. more info for the slk32 than any other forum
Old Sep 17, 2011 | 03:42 AM
03 Slk 32 Amg
will this fit in the slk 32 amg?
http://www.needswings.com/NeedsWings...-srt6dcai.aspx
Old Sep 17, 2011 | 09:31 AM
it will fit if you dont have the supercooler installed. if you do install the supercooler a custom grill is needed
i have this setup and it rocks!
Old Sep 17, 2011 | 02:43 PM
03 Slk 32 Amg
oh well i dont really know much about the parts my car has except for wat i can read... wat is the supercooler? nd would this one fit instead?
Old Sep 17, 2011 | 02:44 PM
03 Slk 32 Amg
oh btw my car is still stock
Old Sep 17, 2011 | 02:50 PM
03 Slk 32 Amg
Well so far these are the mods that caught my attention tell me what you guys think. If getting all of these mods would fit/ work?
or
http://www.needswings.com/NeedsWings...ke-System.aspx
http://www.needswings.com/NeedsWings...t-NWICiso.aspx
http://www.needswings.com/ASP-178mm-...178PSK178.aspx
http://www.eurocharged.com/index.php...mart&Itemid=93
just looking around but dont know if i will be able to afford all of this right away big project of course... btw my car has 115100 miles on it. Is it worth it to do it to or no?
Old Sep 17, 2011 | 06:25 PM
pm sent to you
Old Nov 16, 2011 | 03:02 PM
03 Slk 32 Amg
Are evosport parts good?
Old Nov 16, 2011 | 06:55 PM
depends on what parts your looking at
Old Nov 16, 2011 | 11:28 PM
03 Slk 32 Amg
Their intake cause its much cheaper than the needswing
Old Nov 17, 2011 | 06:42 PM
only thing i see from their website are filters. k&n are better . needswings has a true dual cai.
Old Dec 30, 2011 | 04:48 AM
03 Slk 32 Amg
is this one better
or this one
http://www.needswings.com/NeedsWings...srt6tdcai.aspx
Old Dec 30, 2011 | 04:51 AM
03 Slk 32 Amg
i got 1200$ wat should i get first?
Old Dec 30, 2011 | 06:10 AM
if the dual cai is what you get the thermal coated unit. i have it. just my .02 if i wanted to drop 1200$ i would get the n/w single intake, a eurocharged supercharger pulley and a eurocharge tune. with that you will see about a 60 rwhp increase and a ton of torque
Old Jan 2, 2012 | 01:05 AM
03 Slk 32 Amg
isnt the dual cai better tho?
Old Jan 2, 2012 | 01:06 AM
03 Slk 32 Amg
the set up u said would my car overheat? or is it good?
Old Jan 2, 2012 | 08:52 AM
the dual is a better setup but twice the cost and you have a 1200 budget. the single works great and you can upgrade later to a dual if you want and get credit for the single.
the engine wont overheat. the faster the s/c spins the hotter it gets . if the iat( intake air temp) gets to hot the ecu pulls timing to shut down the s/c to avoid damage. thats were the supercooler, or e55 heat exchanger or other mods to allow the iat temps to be cooler so the power stays on longer. the s/c pulley causes the least amount of heat so thats why i recommend it
Old Jan 3, 2012 | 02:39 AM
03 Slk 32 Amg
but with the supercooler do i need to get a custom grill for the intake to fit?
Old Jan 3, 2012 | 05:54 AM
you could use a e55 heat exchanger or a frozen boost h/e sized approx 26" 14" 2" thick and it would fit without modding the grill. not as big as the supercooler but larger than oem. the crossfire forum is were the info is
Old Jan 4, 2012 | 02:18 AM
03 Slk 32 Amg
should i just save up for a slk 55 amg? haha
