Harman Kardon LOGIC 7
Can it be upgraded at the dealership?
And most of all does it sound GOOD?
Cheers
Tim
Not practical to upgrade at dealer.
Sounds better than the standard stereo which IMO is woeful, but still lacks a rear subwoofer which is nice to have when spending 70k on a car.
I regret not getting in my car, however.
After having the dealer try to fix it over and over, I now keep it in Standard mode because the dealer never told me, or maybe just didn't know, that the HK mode Logic 7 was originally made to interface with DVDs and such that had information the stereo could read. I found this out from one of the smart young guys here at mbworld at a meet. He switched my stereo to Standard and played around with the controls until my stereo sounded SO MUCH better that I knew he was right. That stupid stereo is meant to be hooked up to a tv not an fm stereo system in a car.
I still don't know if it will work with satellite better, the reason I have put off getting satellite. Does anyone know if this stupid stereo interfaces with satellite better than an FM signal stereo?
For the kind of music I listen to (both from radio and CD) I think it is an excellent auto sound system. I not a music major with perfect pitch ear, but I do know sound (I have 2 different full blown component surround systems in my house (party room and TV room). It doesn't quite have the spatial definition the Mark Levinson does, in my Lexus, but it is quite good.
The HK Logic 7 was not set up for car stereos, but home systems - this is a fact.
Also, its not just different pitch, its total horrible distortion that defines the logic 7 mode. In the stereo's standard mode, all is much better, not just in my opinion, but in the opinion of everyone who has listened to my stereo.
But you should have your smart guy do some research on Logic7, basically what he is telling you is NOT "a fact".
In particular for DVDs they all come with either Dolby Digital or at least Dolby Pro Logic surround. Didn't need to invent Logic7 for that.
It is true that HK's Logic7 handles all of that, but in addition to decoding the industry standard surround sound tracks, it adds the ability to take regular 2 channel sounds (i.e. music and singing) and create virtual surround sound.
It is also true the Logic7 started in their high end home audio systems. But still to also enhance 2 channel stereo.
Basically the technology behind Logic7 is a DSP (digital signal processor, think of it as a specialized computer just for sound manipulation and fast) and the software algorithms.
The Logic7 that HK implemented SPECIFICALLY for automobile usage is to enhance stereo signals into a multi speaker surround "sound stage". In particular, for the one in our cars, they have designed the software algorithms specifically to the speakers and placement and volume of the SLK350. This is done for other cars also. Finally it also trys to compensate for top up versus top down and ambient noise.
I am not an HK zealot (this is my first), and the other high end brand automobile configurations do the same thing (i.e. Bose, ML, etc.).
But those are the "facts".
However, if what they designed, does not work for you, that is a valid opinion. I don't have an issue with that.
For me, I think the sound is terrific in Logic7 mode, and occasionally I hear things that suprise me (in a good way, like wow don't remember hearing that guitar lick "over there") that I will go back and play the passage in Stereo mode to see the difference. FOR ME, playing in Stereo mode just sounds so flat, it's like going from listening to a boombox to using a great pair of headphones from a great audio system. In my opinion.
Take care.
When I first brought the car in because of crackling and distortion, the dealer "fixed" it by lowering the peak volume.
The next time they responded to my complaints of distortion, crackling and the stereo nav completely going out and then popping back on a while later by replacing the audio gateway with an upgrade.
The next time after that, they responded to my complaints of distortion and really loud crackling (like a shotgun being firing at me) and the stereo nav STILL completely going out and then popping back on a while later by replacing the audio gateway with an even newer upgrade.
This newest upgrade was to fix the problem of the audio gateway getting hot, like a computer gets hot, except when was the last time you heard of a laptop just quitting completely and shutting down because it was hot??? Was the solution to use a Pentium or something that runs cooler? No, no. They went back about a decade and created an "updated" audio gateway that employs a FLYWHEEL.
Obviously, they made some kind of deal with HK and could care less about the results.
And, I wish it was just my opinion, but not wanting to be a complainer, I asked about a billion people before I went into the dealer to fix or replace the piece of sh*t. The only reason its still in there is because one of the mbworld guys explained the problem with HK and switched it to Standard so I could know what he was saying was true. There was a distinct improvement.
And when my car gets worked on with the dealer, twice since, I'll be driving along with the stereo sounding like AM, only worse, and think I should just get a new stereo after all ... then, a light bulb will go on over my head and I'll check the settings and, sure enough, twice now, the dealer switched the d*mn thing back to Logic Surround. I put it on Standard, play with the Treble and Bass, and all is well with the world again
I don't know where you are, but if you are in CA, you really gotta come out to the next meet and hear the difference.
)I'm in Texas (Austin actually), and it's a SLK55. See my sig/pic on the left. And yes I have NAV.
I promise, I am not trying to tell you your opinion is wrong.
However, I am telling you your mbworld smart guy source is wrong on his "facts" about Logic7. I could post a bunch of links, which would bore you for hours...
BTW, Logic7 is in a number of high end cars, including BMW and other Benz models.
Not that it matters in your situation, but search on the web, you will see people singing its praises (but again it's personal opinion), including "sound people". But of course you will find others that don't like it.
Sorry I wasn't clear on the point, as you are still not understanding what I'm saying about surround sound and DVDs.
The NEW function Logic7 has is to take STANDARD STEREO MUSIC and make it a virtual surround stage.
The world did NOT need LOGIC7 for DVDs, they use the standard 5.1 encoding Dolby Digital or Dolby Pro Logic.
But LOGIC7 is NOT the only technology to do this, this is just the brand name (from Lexicon who actually invented it) uses. Other audio companies have different patented and copywrited technology, with different names.
And if you're ever in Austin, l would love to let you listen to mine (and then perhaps you can convince me I'm halluncinating!).
Works perfectly fine over here and sounds very nice and clear, even if the rear speakers could do with a bit more oomph. But a very minor point IMO.
Honestly, the stereo in my HONDA Element sounds WAY superior to the piece of **** in my MERCEDES. I knew that wasn't right, but the dealer kept acting like everything was okay and normal with that piece of sh*t
Will you guys please confirm that the sound actually changes when you adjust the control while in Logic 7 Surround. I'm sure it does, but I want to be clear when I attack ... I mean, call ... my dealer.
I experimented a lot on the drives (last night top down, this morning top up). I switched back and forth between Stereo and Logic7 (and threw in Speech once or twice just to see). I'm talking about switching every 10 seconds or so. I also tried different music. Though right now I'm loaded up on rock (everything from my teenagers Velvet Revolver and Godsmack to the sound track from Lords of Dogtown with some good rock "oldies"). But I did go thru some hard driving rock and then some basically singing ballads.
There is just no compare.
I also tried driving the Treble and Bass to max in both (I normally keep them right at default), to see if that "messed" things up. It didn't.
I did find that on some music the change/effects was less pronounced than on others. But it was NEVER worse, and for 75% of the cases sounded MUCH better.
I tried it with volume low, volume normal, and then really rock'n!
The best verbal picture I can paint for you is this:
Imagine there is a room with either a live band or a really good surround audio set up.
Then imagine you are standing just 2 feet outside an open doorway to this room (regular size door) and listening. This is STEREO mode. Music sounds good, but the "sound stage" seems small and directly in front of you.
Then imagine you step thru the door a couple of feet into the room. The "sound stage" widens and seems to surround you. This is Logic7.
Again, do not listen to either MB dealer or other "smart guys". You may or may not care for the virtual sound processing Logic7 does vs Stereo, but there is NO WAY you should feel it is unimaginably worse and unlistenable.
Suggestion: take a store bought CD (too many quality varibles if you use ripped MP3 or Itunes). Listen to it (or some of it) in your home system and get familiar with it. Your home system does NOT have to be a surround system, just a good audio system. The put it in your car, listen to the same passages again in STEREO. Then start switching between STEREO and LOGIC7. If LOGIC7 is as bad as you say on this CD. Then get to your Dealer/Service person and go thru it.
If he tries and tells you LOGIC7 in your car is only for DVDs, then tell him he's FOS. And then come back here and I'll send you the pointers for the whitepapers and press releases, etc. from the web.
Second, now that I have something concrete that proves the stereo is not working right, in at least one way, they have to acknowledge that the stereo is BROKEN.
Third, much thanks for the description on what surround sound should sound like. I actually had it where I lived a few years ago for the tv and den, so if the HK is capable of sounding like that, mine is WAY OFF.
Thanks again everyone. I'll keep you updated. The car is the best, but since like days after I bought it, I have been bringing it back to the dealer over and over because of this d*mn stereo, the reason I was so willing to believe it was meant to sound crummy.
Interference Noise From Speakers
Here is the address typed out in case that doesn't work:
http://www.alldata.com/tsb/Mercedes-...0_P-82-62-387/
Read it, you will see sounds just like your symptoms ("Poor sound while in Logic7 mode in all audio sources").
You have an early build car right.
Also, have them check this TSB also, talks about updates to the COMAND audio software they should install.
Audio System - Inoperative and/or No Right Channel and/or Memory Inoperative.
Let's hope you get the system fixed right up so that it sounds as good for you as it does for the rest of us =)
Btw: when DID you get your car? Mine was built in October of last year, so you'd think it would belong to the bunch of 'early' builds... yet I don't have any of these problems
