slk63 confirmed by edmunds for 2007
AFFALTERBACH, Germany — Of late, AMG has concentrated on artificially aspirated engines, namely supercharged V8s and turbocharged V12s. But that's all about to change when Mercedes-Benz's performance division unveils its new V8 at the Frankfurt Motor Show next month.
Dubbed the ML156, the new normally aspirated 6.3-liter V8 will make its Frankfurt debut in the Mercedes-Benz ML63 AMG. The engine delivers 510 hp at 6,800 rpm and 465 pound-feet of torque at 5,200 rpm. AMG officials told Inside Line the large displacement allows 20-percent more torque than its chief competitors, while at the same time being lighter, more fuel-efficient and more drivable.
After it debuts in the ML63 AMG, the engine will go into the CLK63 AMG and E63 AMG, likely to be unveiled at next spring's Geneva show. In late 2006, the engine will make its way into the R63 AMG, and in early 2007, it will go into the C63 AMG and SLK63 AMG.
The ML156 engine won't be fitted into the AMG versions of the new S-Class — premiering at the Frankfurt show — the CL or SL until at least 2008. Those vehicles will feature more powerful versions of their current engines.
While this new engine is normally aspirated, AMG officials said the division will remain faithful to turbocharging where it makes sense.
The car you buy in the store is a compromise between performance, safety and durability. If you want to just go-for-it and to heck with the life of the engine then forget Kleeman, forget pulleys, forget chips ..... just leave it in AMG for another month and leave a blank check as you walk out the door.
After seeing the specification, design and build of a W208 racing car .... all I can say is carbon fibre is not just for looks - serious builders actually use it to increase body strength at low weight. Air suspension is an option too ... now I dont know if that is the semi-active or the fully active ABC version.
Stock machines are just consumer toys.........
The big boys will get TT versions of the 63 for some real grunt.
Enjoy your rides everyone.
Cheers!!
dasrok8
aka George
Cheers!!
dasrok8
aka George
