Dean from MBenzNL (awesome guy!) is in the garage installing a few things right now:
Euro Command
Navigation
Rain Sensor
Digital Climatronic
Euro Command
Navigation
Rain Sensor
Digital Climatronic
Dinko,
You must have the most tricked out SLK55 in the whole country! Props to you and your tremendous effort!
Dean had just asked me to bring him a DVD to test out the unit and it sounds AMAZING! Better than my set up in home. The HK sound system is really put to work, and it made my head turn in one of the scenes in he movie!
Absolutely speechless... The Video is also better than any TV I've ever seen.
nice ...
what movie is that with the hourse?
ExploreAlmost a Member!
So how does someone get a hold of that verion of the NAV/DVD player, and if you don't mind my asking, how much?
In my older LK32, I had a top of the line DVD/NAV/XM system put in by a local shop and I loved it (The screen popped out to view).
Stealth - The part with the horse is a preview of the new Zorro movieOriginally Posted by JosephN
nice ...what movie is that with the hourse?
www.mbenznl.com or steve@mbenznl.comOriginally Posted by WDRiley
So how does someone get a hold of that verion of the NAV/DVD player, and if you don't mind my asking, how much?In my older LK32, I had a top of the line DVD/NAV/XM system put in by a local shop and I loved it (The screen popped out to view).
Here is a shot of the trunk after completed, only thing left is the rain sensor which Dean is having a little trouble with:
Quote:
To resolve the rain sensor issue - Originally Posted by dinko
1/ Determine the part number to be installed
2/ Look in developer menu of OCP to see which code page setting relates to the part number being installed
3/ Remove old sensor - if removed totally and not split apart then also remove silicon layer left behind
4/ If necessary clean the glass with large amounts of paper
5/ Apply the new sensor
6/ Code EIS / System Diagnose RAIN SENSOR = PRESENT
7/ Initial startup on OCP and set codes as needed and perform normalisation.
Should work.
Should work.
We already tried that same step many times. Still didn't work. Since there are multiple "Rain + Light Sensor" parts, he will get all the possible ones, and try his luck next time.Originally Posted by benzmodz
To resolve the rain sensor issue - 1/ Determine the part number to be installed
Should work.
For now, I'm more than happy!!!
Dinko
Dinko
Refer back to step II - there is no need to buy more than one part number. Originally Posted by dinko
We already tried that same step many times. Still didn't work. Since there are multiple "Rain + Light Sensor" parts, he will get all the possible ones, and try his luck next time.For now, I'm more than happy!!!
Dinko
Part numbers and coding
https://mbworld.org/forums/slk-class-r171/120629-r171-rain-sensor-part-numbers.html
My install in Sydney
http://www.mbcnsw.org.au/forum/viewtopic.php?t=458
Have a look inside the package
http://www.mbcnsw.org.au/forum/viewtopic.php?t=425
Make sure you have the right parts.
Former Vendor of MBWorld
Hi Dinko,
I am glad that we got it to work out before the beginning of 2006...good to know that you are happy with the results!
greetingz,
greetingz,
greetingz,
Thanks Steve, looking forward to doing more with you guys. Dean can tell you what else I have in mind Originally Posted by MBenzNL
Hi Dinko,I am glad that we got it to work out before the beginning of 2006...good to know that you are happy with the results!
greetingz,
Dinko
Does MBENZNL have a DVD playback kit that can be adapted to the regular North American Command/Nav systems?
Quote:
It was featured in his most recent images of his own car build. He has both single slot, multi slot and DIVX hard drive systems.Originally Posted by MPRESION
Quote:
The US spec comands do not have the hardware inside the comand to play DVDs...not at standstill and not in motion.Originally Posted by MPRESION
greetingz,
did you have any problems installing the conformatic module ????
maybe it is PLUG&PLAY ?????
Quote:
Yes, plus & play
Mine is December 2004.... is it ok ? Originally Posted by dinko
Car is a 05Yes, plus & play
Dinko... compliments for the installation! I have the Audio 50 Nav sistem... and i would like to install the command too.... i need also the car navigation dvd player ?
Could you tell me how much is it all the installation including the conformatic module ??
Thank you
Max
Thanks..
Your car should be fine, I think mine was produced even earlier than that since I took delivery in November 04.
I dont' remember how much I paid, contact MBENZNL for that.
Currently Active Users (1)
