performance package info please
When I drive the 650ci it really feels like your connected to the road and the car is an extension of yourself. I have been a benz guy since i was 16, have driven nothing but mercedes. So my question is what how does the performance package better the handling? How is it different? Any comments?
I want to keep the slk but i want great handling as well.
THe 030 adds heavier wheels which is counterinuititive.
Your handing will be much better if you got lightweight wheels and some adjustable coilovers such as the KW variant3s.
The 030 adds nothing to benefit performance. Revalved shocks and heavier wheels ain't going to do jack squat.
But the SLK is still much lighter than a 650ci. I can't see how that overweight car would handle better than a stock SLK55. Maybe it depends on what you define as handling.
Steering feel and lateral grip often have poor correllation.
In the 650, even though its slower and heavier you can take turns at much higher speeds and never feel out of control. When you move the wheel just a tiny bit the car turns a tiny bit. For example when i turn my slk weel just a few mm the car doesn't turn, there is some give in the tightness of the steering wheel.
In the bmw, the damn car sticks to the road no matter what and it feels like ever movement on the wheel is mimicked perfectly by the car.
I know what you mean by road & steering "feel", but don't let it fool you. The SLK55 handles every bit as well as any BMW (see above). And as Tromp said, lower your unsprung weight & get a wider & softer compound tire. If you want to push further, get some thicker anti roll bars, lowering springs from Barbus or Kleemann, & presto - a firmer/more sporting ride awaits.
See ya,
-Matt
get Michelin PS2 and you will be ok.... I think you are using Pirelli ...
You say the BMW sticks to the road no matter what. Does this mean that you and oversteering and understeering too much in the SLK? I would doubt it unless you are on a racetrack. You can get power-on oversteer quite easlily if you want to in the SLK, but thats because it has massive torque. If you are over or understeering while cornering on public roads in the SLK, I suggest you are driving too fast.
This too changes the feel of the vehicle when turning the steering wheel... can be the reason why the feel is so different.
Any tire recommendations? ps2''s? what size?
However, there are some general things you might consider. Stiffer shocks, particularly compression on teh front of the car, can make the car feel a LOT sportier, and actually show up on times in autocross.
Try 10psi more in all tires. May very well cause weird tire wear for a long term solution, but can give you hints.
A little toe out increases steering feel.
Less caster helps sporty feel, but can actually hurt ultimate performance.
If money is not an issue, try a set of the Kumho autocross tires. Pretty impressive, and I would guess you would get safely over 1 G laterals.
hope this helps,
doug
same OEM sizes ..... PS2 Michelin
Also note that you have a very heavy engine in your snout that can generate some understeer that will effect cornering, which can easily be corrected with all the power that this car has. All in all, this car counter balances well, lets the tail kick out in corners when you want it to and makes for a very good experience.
ps2's on my last BMW and did like them. The slk has gobs of power so you have to be careful about driving into corners. Come in fast, slow through corner and hit throttle as car straitens to avoid oversteer. Very long front on this car and lots of weight from V8. Once you get used to it, which does take awhile, you will understand. Much more like driving an older Ferrari GTB type then anything on the market these days.
Thanks for all the info guys, keep em coming....and whats paramter steering option?
1 Factors that affect a car's handling
1.1 Driver
1.2 Familiarity
1.3 Weather
1.4 Road condition
1.5 Weight distribution
1.5.1 Center of gravity height
1.5.2 Roll angular inertia
1.5.3 Center of gravity forward or back
1.5.4 Yaw and pitch angular inertia (polar moment)
1.6 Suspension
1.7 Tyres and wheels
1.8 Track and wheelbase
1.9 Unsprung weight
1.10 Aerodynamics
1.11 Delivery of power to the wheels and brakes
1.12 Position and support for the driver
1.13 Steering
1.14 Suspension travel
1.15 Electronic stability control
1.16 Alignment of the wheels
1.17 Rigidity of the frame
Steering is only one factor in a cars handling. Every manufacturer has its strengths. MB's steering may be described by some as a bit vague, but for some thats what makes a Benz a Benz. Parameter steering makes it easier to park but may take away some driver feedback at higher speeds. An extreme example of this is found in electronic steering such as in the Passat.
IMO my frontwheel drive TT with a limited slip differential has a better steering feel than the SLK, but FWD has other limitations that are part of the handling equation.
The powertrain, supension and frame rigidity (amazing for a convertible) of the SLK blow away the competition. It's a matter of preference.
PS2's may or may not make you happy as they seem to be a cut above all other tires.
I'd rather a car that was fun 90% of the time and decent that other 10%
than a car that was great on perfect roads only.
See that FEEL... means you FEEL the road, including trammelling. Thats when the wheel will fly all over the place following the grooves in the road. When you have tto keep constant pressure on the wheel to keep it straight....
However, although this will increase the feel, it will have essentially no other benefit. The car wan't have any more grip and won't be any faster through corners.
