SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
V12 Twin Turbo in SLK
Old Oct 30, 2006 | 01:17 AM
  #151
ZedStyle's Avatar
Youngtimer
Originally Posted by benzmodz
I saw zoolander .... I know where this thread is heading.
DANCE-OFF!!!!!
Old Oct 30, 2006 | 09:21 AM
  #152
Derelique's Avatar
SLK55 AMG
It's a Walk-Off.
Its that damn Hansel, Hes so hot right now.
Old Nov 10, 2006 | 03:55 AM
  #153
RW C55's Avatar
'10 E63 Obsidiant Black; '06 R350 Alabaster White; 05 C55 Obsidiant Black (sold)
Any updates?
Old Dec 2, 2006 | 12:57 PM
  #154
cantdriveonly55's Avatar
2007 Alpina B7
Anything?
was it all a scamming troll?
Old Dec 7, 2006 | 05:43 PM
  #155
Derelique's Avatar
SLK55 AMG
NO WAY.
Im sure he was the real deal, the pics of his cars were so convincing
Now i would like everyone on this forum who was....how do i say this nicely...hmmm....RETARDED enough to believe this fool to now apologize to your hero and mine.....MR. Derelique.
Old Dec 11, 2006 | 04:27 PM
  #156
Ghostrider's Avatar
01 CLK 430
Originally Posted by Derelique
NO WAY.
You scared him away.....
Old Dec 12, 2006 | 10:01 PM
  #157
anorphirith's Avatar
the 2 guys are 1 .... this topic is so lame it should be deleted
Old Aug 25, 2008 | 09:50 PM
  #158
C32AMG/02's Avatar
Originally Posted by C32AMG/02
Automatics are better suited for transmitting and managing high torque to the pavement. Torque converter and electronic controls of the automatics produce firm but smooth shifts eliminating the number one cause of transmission failure, driver train shock load.
The 7G Tronic transmission is more then capable of handling high torque motors. MB rates there transmissions in terms of continuous and momentary loads, momentary are rated 35% higher. The 7 speed W7A700 transmission torque continuous load rating is 700Nm, /560ft/lbs x 35% (momentary load) = 756ft/lbs. There will never be a time when that motor will produce 756ft/lbs of continuous torque.
TCMs are also variant coded, Rear end ratios/ transmission ratios are written into the transmissions control module, if you use an automatic transmission and if not matched to the car, soft ware wise the transmission will go into limp mode when a gear ratio error is seen. You will need the help of a tuner should this happens, also the 7G transmission torque converter clutch apply shift strategy is ; I would install an auxiliary transmission cooler in series with the exciting cooler, if you decide to use an automatic the 722.6 is a better transmission.
Good Luck with your project.
