Quickest SLK55 N/A?
The link above show the top two SLK55s in the 11s are S/C.
The last four SLK55s on the list are N/A and the times average 12.761 in the 1/4.
I'm curious to know if a full Renntech/Kleeman N/A modded SLK55 can break into the 11s.
Thoughts?
Perhaps you should add the following mods then take it to the track and report back. That’s the only true way to find out.
Kleemann Cams or VRP/PET Cams
RennTech CF Airbox or 55K Air Intake
Bigger Throttle Body
Power Pulleys
Long Tube Headers
Full Exhaust
ECU/TCU Dyno Tune
LSD
Lighter Wheels
Drag Tires
¼ Mile Driving Skills
Power Pulleys
Long Tube Headers
Full Exhaust
ECU/TCU Dyno Tune
LSD
Lighter Wheels
Drag Tires
Renntech CF box is expensive, best bet is drop in filters and cut through the internals of the oem box which isnt expensive compared to the CF box which costs 2,000 usd I believe for +10hp.
I've got Kleemann 2ndary cats 200cell, Supersprint xpipe, Kleemann headers with the primary cats deleted, drop in filters and an ecu upgrade. Hopefully in a couple of months I would like to purchase Kleemann camshafts and report to you guys. The car is now very quick but you get used to the power, Kleemann reported to me and said your looking at +15-18hp on my current setup which is around 400-10hp.
I know larger throttle bodies aren't available for our engines, but they can be achieved by modifing the intake manifold.
I usually would not recommend power pulleys, but if you're trying for 11s then you're going to need all the power you can get out of your N/A 55, so they are a must. Same goes for the Renntech CF Airbox, but your best bet would be to fabricate some custom air tubes straight from the throttle body to the front of the car with K&N cone filters.
The VRP cams are more aggressive than the Kleemann cams and Supersprint seems to have the best long tube headers for our cars so that would be the best combination.
Instead of installing a S/C, perhaps I should keep mine N/A and see what's the most I can get out of it.
alroumi, if you purchase the Kleemann cams please report back with your results.
Step 2: Camshafts, new tyres.
Camshafts, sounds great seen a couple of youtube clips and adds more power. Keeping it N/A helps the gearbox without abusing it too much and adds torque.
Maybe in the near future, shaving the heads or other internal mods.
http://www.dragtimes.com/Mercedes-Be...lip-12032.html
http://www.dragtimes.com/Mercedes-Be...lip-16672.html
Needless to say, the data is all over the place for both the C55/SLK55.
Maybe I'm a bit optimistic but I believe that the right conditions, mods, and driver could yield 11.9x-12.1x times which is incredible feat for such an awesome roadster.
I wasn't sure if you were aiming for 11's or not, I was just responding to Juggarnaut's initial question about if a full Renntech/Kleeman N/A modded SLK55 can break into the 11s. I'm just not sure if Renntech or Kleemann has enough mods for our N/A 55 to make that happen.
I agree!
- Headers
- Crank pulley
- High flow 2nd cats
- ECU upgrade.
The first two make the biggest difference in torque (thus acceleration) out of all of them. Cams won't give you much power except on top end and for the $$ required to install them its not worth it at all really. Throttle body will only really help once you have done all these other mods previously.
Other then that the only thing you can do to really make a big difference is get the best tires money can buy: Dunlap Direzza Z1s. They really blow every other tire out of the water and work especially well on the R171 SLKs.
If you do all those, you will get the performance you are looking for. You can get the headers & pulley in the AMS stage 2 performance package which will save you an additional $100.
Hope that helps,
http://www.autotech.com/quaife/index2.htm
Maybe it has to be ordered from UK? Do you know how much it costs? Is that what you have alroumi?
- Headers
- Crank pulley
- ECU upgrade.
I understand that you have to promote your products, but don't try to restrict us with only these small mods.
I guess I’ll have to modify or fabricate an intake manifold that flows better and accepts a larger throttle body which will help contribute and benefit an aggressive camshaft. That’s the only way to get a N/A 55 to breathe better and reach its full potential.
How about offering long tube headers in addition to your shorties and a better flowing intake system that will help the engine breath better.
TH Motorsports 2095 Johns Ct, Glenvieww, IL 60025
1-800-959-1045
1-847-656-2392
www.thmotorsports.com
http://www.slkworld.com/slk-r171-gen...package-2.html
Camshafts I think will help. If there is one aspect of this FI car I want to still modify is the performance at the high end. There is so much down low but it seems to slowly go away at the high rpm. I think camshafts would address this issue.
Also I had the AMS crank pulley ... I pulled it off.
I would really like to see how your RENNTech S/C or a simular S/C set-up on a N/A 55 would respond to the addition of some VRP/PTE aggressive 55K cams.
Hmmm... Did you pull it off because you added the RENNTech S/C?
The reason I pulled it off was because I noticed a slight wobble. I didn't want to take any chances so I pulled it.
