SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
Understeer problem in the SLK55
Old Dec 20, 2009 | 04:30 PM
Juggarnaut's Avatar
I've see a couple videos online on the SLK55 and there was a consistent issue of understeer in the SLK55 which could be solved with punching the gas pedal to induce oversteer. Has anyone here addressed the understeer issue on the SLK55, maybe wider front tires? Sway bar? or something else?
Old Dec 23, 2009 | 02:00 PM
SLK55R's Avatar
'10 Porsche Turbo PDK, 500e, GL450
what have you tried
regarding your suspension? I've gone with KWv3 coilovers and they do seem to help a lot.
Old Dec 23, 2009 | 07:22 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
Tires, upgrade your tires and that will make a significant difference. With Dunlap Direzza Z1s almost zero understeer on the R171s. The Z1s run a good 1/2 to 1" wider than normal so you can stick with stock sizes and still see big improvement in the way the car looks & performs.
Old Dec 24, 2009 | 12:30 PM
imducati's Avatar
slk55 2005; e320 2004 sport
I went with the strut brace bar which made a massive difference:
https://mbworld.org/forums/slk55-r17...strut-bar.html
I also go these tires which took some time to break in, but are excellent:
Sumitomo HRTZ III mounted (245/40/18 front and 265/35/18 rears)
Old Oct 26, 2010 | 06:07 AM
kenysl's Avatar
SLK 55
Hi imducati,
Can you elaborate a little more on the benefit of the strut brace on your slk 55? so the response has change a lot?
What about rear strut, have you changed that too?
Old Nov 20, 2010 | 01:03 AM
imducati's Avatar
The front strut brace causes the turn-in to be a lot sharper and seems to understeer less.
Old Feb 17, 2011 | 12:45 PM
nmslk's Avatar
'05 SLK55 AMG
Is the strut bar you bought specific to the SLK55 or is it made for the 280/350's and it happens to also fit the 55?
What is the part# at Wiechers Sport?
Thanks,
nmslk
Old Feb 17, 2011 | 05:34 PM
A' La F1's Avatar
2006 SLK 55 amg, 2002 CLK 430 Cab (hers), 1989 944 Turbo (sold), CLK 500 (sold), 125cc shifter kart
Lowering (best with coil overs) coupled with the strut brace did the trick for me. Also the LSD made a huge difference. All in now a proper handling sports car. Here is more info on the strut brace:
http://www.slkworld.com/general-disc...ther-r171.html
