SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
07 SLK55 - Maximum Rubber on Stock Rear Wheels?
Old Jan 24, 2010 | 02:29 AM
esqdg's Avatar
07 slk55 w/ Quaife LSD
i need new rears soon on my 07 slk55. was thinking of getting ps2's in 265/35/18 for the stock amg wheels. this is possible without rubbing or any ill effects?
i am looking for more power to the ground and less big yellow ! on the dash.
Old Jan 25, 2010 | 11:07 AM
dantejazz's Avatar
SLK55 AMG - DTM Conversion
I am running Nitto 265/35's on stock 18's and have not had an issue. Plus, the suspension was dropped almost an inch for stiffening. Hope that helps.
Old Jan 25, 2010 | 12:47 PM
esqdg's Avatar
thanks. i ended up needing new rears yesterday as the right rear picked up a nail. 265 indeed does fit.
Old Mar 25, 2010 | 07:21 PM
phoung's Avatar
'03 clk 500. WTB slk55
if a 265 35 can be mounted on a 18x8.5 than a 265 40 can be mounted on a 17x8.5, mabye even easier correct?
Old Mar 27, 2010 | 11:40 AM
CLK Masters's Avatar
04 CLK 500, 07 GSX-R 750, S 550, 09 Jeep GC
slow down a little, if it's for your CLK 500. it will rub a little on bumps and even more if your car is dropped.
so yes you can go 265, but as far as the stock wheels i wouldn't go past 255 on the 8.5 rim.
but then again it depends on the tire. I have Yokohama AVS ES 100, and the smallest rim they recommend to put a 255 on is a 8.5. i'm guessing they would recommend a 9 inch rim for a 265.
just something to keep in mind.
Old Apr 19, 2010 | 08:13 PM
Ppower's Avatar
SLK55, Mustang 480hp, CBR600rr
I agree with that the largest tire you should stick on 8.5" rim is a 255. If you want 265 or bigger need a 9" or bigger rim. But, then may not fit or you have rubbing issues.
Old Apr 27, 2010 | 01:57 AM
imducati's Avatar
slk55 2005; e320 2004 sport
I have 265 on stock 8.5 for the last year and they are wonderful
Old Apr 27, 2010 | 02:57 AM
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
What brand of tires are you running?
Old Apr 28, 2010 | 07:19 PM
imducati's Avatar
Sumitomo HRTZ III mounted (245/40/18 front and 265/35/18 rears)
Old Apr 28, 2010 | 09:26 PM
Ppower's Avatar
Again you may think they are wonderful, but the manufacturer doesn't agree with you. Just because you can stuff it on the rim doesn't mean it fits correctly and makes a correct tire contact patch on the road or handle correctly.
http://www.sumitomotire.com/assets/p...e/htrz3_sm.pdf
note: smallest recommended rim for at 265/40/18 HRTZ III tire is a 9.0" rim, designed rim width is 9.5" The same holds true for their 265/35/18.
