SLR/C199/R199/Z199: SLR McLaren - Break Squeal - LEMON???
It can be fixed..there is a gas inside the pads that needs to get released- one problem, most people won;t seat them properly, or don't have a place to do it....lets just say you need a lot of space and no traffic..did it once, you think rollercoasters make you want to hurl...All the SLR techs I have talked to that went through the procedure have said the squeal is gone..Got another one in today..for other things, but it needs it BAD..
Yep.
All new brake pads and rotors should be broken-in properly - but especially performance ones -- and I suppose most especially ceramic systems....
And all new performance rubber should likewise be properly heat-cycled and rested....
I complained for weeks ,then mclaren sent a newley designed set of calipers and pads,we'll see.it was getting so i would pick somthing else to drive that day.wen i was on the in car phone people would hang up on me wen ever i had to break .aside from that im reasonably happy with the car .
My friends dad purchased an slr in April from fletcher jones and he is going to lemon the car because of the brake noises. Supposedly, mercedes ordered new brakes but his been waiting for them for a while. He have has a black/black one at the moment but after he lemons it, he might get a different color.
ive been driving with the new calipiers and pads for 3 days now and they dont make any noise but i have noticed a diference in performance .my rep says they just need to be bled bettr ,in 2 weeks they want a full report from me but i would rather have the performance and put up with the noise if it keeps me from pilin into the back of some grandma at 300
W203 slightly modified
" Let me loose you b_stard .... I dont want to go slower ! "
Do you actually think people are going to believe you own an SLR when you can't even put a proper sentence together??
Why bother? It will make the same noises, unless they are broke in right and drove in such a manner as to keep them broke in. The chances of actually winning a lemon suit over this is awefull slim though- it is the nature of the beast, same as them catching on fire when on a race track The brakes I mean)- they do that.
Too many people own these cars that don't realize what it is, they just figure it's an expensive car- wrong- it's a super car and so it should not be expected to be like an SL, or an S-Class.
Bigsugar- I have seen new pads, but not calipers yet- if they weren't bled properly, the SBC would know it, and the bleeding procedure would not have finished. BTW..the parts come from MB- not Mclaren.
well if thats the case performance is cut in half with the new pads and calipers pluss they r ugly.im willing to put up with the noise ...case closed.
The fact that you said they are ugly suggests that they put the red calipers on in place of the grey ones. They are the same caliper- just different color.
It sounds like they are not seated yet, the procedure involves stopping 8-10 times just before ABS deployment from 70-0, one right after the other- thats what makes doing it kind of hard. If you are in Vancouver they should have a dyno they could do it on. My brother and sister both live in Vancouver.
benzmodz.. as far as I can tell from the videos I have seen (I've never got one hot enough for that), its the pads and the air around them. It usually happens if you stop driving after using them to their max, I guess they need a cool-down lap.
[QUOTE=MBTech21]The fact that you said they are ugly suggests that they put the red calipers on in place of the grey ones. They are the same caliper- just different color.
no i ordered the red ones in the first place the new ones are bigger my rep from toronto said they are weighted or somthing ,he also said they were like the calipers on the maybach . i tryed seating them last night and they work a little bettr the pedal is still way too soft and now they make noise again (not as bad though) .and vancouver dosent have a dyno .
slr brakes
First of you cannot lemon law an SLR on brake noise for two reasons, first it does not meet any of the lemon law criteria, i.e, safety, value or performance, and secondly, when you took delivery of the vehicle from the dealer, you signed a piece of paper(weather you knew it or not) saying that squeaks, rattles, and weird loud noises were normal for this kind of vehicle.
Also the modified pads and callipers, will take car of the noise, but if you track the car, the noise will come back.
Proper "de-glaze procedure is, 100km/h to 30km/h at half brake pedal, 10 times,
then 100km/h to 30 km/h with full brake pedal 10 times with full abs intervention by the 4th attempt.
then drive 5km to cool of the brakes and prevent glazing.
This works, and I got a ticket from LA PD for recless driving doing it in a clients car.
Another thing to consider, for any owners, if you have changed the wheels on an SLR, you have totally screwed up the under body aero and cooling of the car.
the wheels are that design fo a reson not just looks!! br careful
First off, we have already talked to a lemon law attorney, actually the largest in L.A that states that he can lemon the car for this reason. Second off, mercedes never made us sign a paper stating that the brakes can make noise. If we new about this issue before, we wouldnt have purchased the car. Hello??? And actually, for the first 1000 miles, you have a brake in the brakes very calmly. You cannot purchase the car and head to vegas. You have to drive it normally. After that you are recommmended to open her up. The car currently has 1600 miles on it and we have opened 130. That isnt a lot, but this problem should not occur in the first place.
Brakes and tyres require a 100 mile break in, it is the drive train and power plant that are limited to 4500rpm for 1000 miles.
You said you called a "lemon law" attorney, did you think he would say he can't win the case??
Be very carful, MB have very good attorneys, and don't don't very often loose in court.
I was one of the first MB techs to be SLR certified, and currently maintain and service over 7 SLR's and have well over 5000miles driving in various vehicles, both here, in Europe and on road and tracks.
Dont want to get into a pissing contest, but if you would like some free contructive advise please feel free to call me. 818-521-2332, happy to help of just fix the car.
Where did you buy it?, give me the last eight of the vin, I will run the VMI and check the history for you.
not sure who did the delivery of the vehicle for you, but they did not explain the breakin procedure correctly.
