SLS/R197/C197 AMG: Gullwing strut replacement
I'm wondering if there's a DIY procedure (or video) out there with the right part #s to order, etc. It should be a very easy/quick project but likely need another person to hold the door up (or employ a very long broomstick).
That you are, David !
I speak on behalf of other members when I say we appreciate your contribution to this forum.
Thanks!
J
Took the SLS mechanic less than 5 minutes to place all of them.
That was 1 1 /2 years ago and they have been perfect since.
You can find it on the usual online sites
https://www.genuinemercedesparts.com/oem-parts/mercedes-benz-gas-pressure-strut-1979800064
https://www.mbpartsworld.com/oem-par...rut-1979800064
The first strut I was able to finally take out by getting full “yanking” power running 90 degrees against the ball/socket joint. When I simply tried to pull the strut from the ball joint it would not come undone (at either the top or the bottom sockets). So I sort of leaned against the car, getting the full length of my arm extending and the full power of my upcoming yank running lengthwise with the body of the SLS, which is directly outward from the ball/socket joint. A hard yank finally popped it out. That was the bottom socket, which in my opinion is the better place to start. The top socket was easy to remove after that.
Then I had someone hold up the door while I put the new strut into place. I had to press very strongly to pop the top socket into place and the same for the bottom. Once it is in place you know it as it “pops” into place.
The 2nd strut was even more difficult to remove. Yanking didn’t work. Neither did striking lightly with a hammer. Finally a screw driver was used to “jimmy” (sp?) in between the ball joint and the frame. This did pop out the strut. I suspect this method is not recommend by MB. But it worked and I was able to replace the 2nd strut.
good thing you got the EW
