SLS AMG Gullwing (C197, R197) 2010 - 2014
SLS/R197/C197 AMG: SLS Factory Trickle Charger?
Old Jan 9, 2016 | 08:10 PM
Jeff SD's Avatar
SLS Roadster
I'd like to purchase a factory trickle charger for my SLS. There's a trickle charger receptacle in the trunk, but I can't find a charger with the correct connection.
The charger's i've found are either battery post or through the cigarette lighter receptacle.
Jeff
Old Jan 10, 2016 | 12:43 AM
Tjandegi's Avatar
G63, SLS AMG, Shelby GT350
Local dealer can't source you one? Sure it'll be 20x more expensive than those on the market.
Old Jan 10, 2016 | 01:28 AM
NewportSLS's Avatar
SLS AMG
http://www.mbpartsworld.com/p/__/CHA...009820221.html
Old Jan 10, 2016 | 01:31 AM
WLA SLS's Avatar
SLS, SLR, CL63, G-Wagon
I purchased the CTEK MUS4.3 trickle chargers for my SLS's and they are great. I think they were about $60-70 each on Amazon. The same charger is OEM for many high-end auto manufacturers such as Ferrari, Lamborghini, etc. I can barely change a light bulb but I had them connected to the battery terminals in my cars in less than 5 minutes. In terms of ease of use, once installed, it is basically same as using the connection in the trunk.
James
Old Jan 10, 2016 | 01:41 AM
Tjandegi's Avatar
If I ever need to find anything online I'm just going to message you...online wiz haha. Took me forever to find the rubber door seals on their parts page.
Old Jan 10, 2016 | 02:07 AM
NewportSLS's Avatar
SLS AMG
I'm a Google maniac.... The Parts Link thread is invaluable...
I'm like Jeeves but for SLS Sh$%
Old Jan 10, 2016 | 11:26 AM
Jeff SD's Avatar
SLS Roadster
Couldn't agree with you more..David is an asset to this forum. :Thanks , D!!
Placing my order tomorrow
Old Jan 11, 2016 | 12:00 AM
NewportSLS's Avatar
SLS AMG
Thanks! I try...
PS I use a battery tender plus. The first time I charged up it took 2 and a 1/2 full days. Now It takes about 12 hours every 2 weeks.
So, don't panic if it takes some time to get to full charge.
Old Jan 11, 2016 | 08:39 PM
1st amg's Avatar
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
I have the oem version, it is more expensive, but it is exciting to see how it is made for the sls only with its magnetic ports and connections.
Old Jan 11, 2016 | 10:33 PM
Rbcj50cal's Avatar
2011 SLS AMG coupe, 1997 Yellow/Blk Hummer H1, 2014 Monterey Blue SLS AMG GT roadster
Nick, I would agree with you on the charger.
Old Jan 11, 2016 | 10:56 PM
Jeff SD's Avatar
SLS Roadster
I ordered one from the dealer $185.00..It should be here on Thursday.
Old Jan 11, 2016 | 11:15 PM
NewportSLS's Avatar
SLS AMG
Just for kicks see how long it takes if you can. I know not scientific since, we don't know charge level but, always interesting...
Old Jan 12, 2016 | 10:49 AM
Sandy Eggo's Avatar
'00 SL600
Sorry about that. BTW, our local dealer has a web coupon for 10% off on accessories. Amazingly, they consider the charger a "part" but I managed to get them to honor the discount.
I've brought batteries back from dead with a trickle charger. Usually takes about 24 hours on the drip feed. The point is to not let it get that bad. With the quick connect in the SLS, it'll be easy to hook up if you know you won't be driving it for a few days.
Old Apr 29, 2016 | 01:16 AM
Edez mb's Avatar
E350, SLS AMG, Z8
I'm just getting up to speed on the SLS. I have the SLS specific connectors for the trickle charger, but no charging unit. I'll correct that soon, but was curious when charging the battery is the trunk left open?
Old Apr 29, 2016 | 07:45 AM
1st amg's Avatar
I do not leave the trunk open, if you position the wire coming out of the trunk to the side a bit, the trunk will slam shut. If you are charging the battery directly under the hood, then leave the hood un latched, that way the battery when heating up has the ability to breath. As far as the trickle charger kit, I had a thread that I posted pics of the factory cables that came with the car that connect with the OEM trickle charger from MB, the cables connect with magnets, pretty impressive.
