SLS/R197/C197 AMG: Almost died in my SLS...
Opened the door with manual key. Popped the hood. Jump started the car using a jump start battery. Drove the car around the block twice and parked the SLS back to the basement parking of my building. Shut down the engine and I could not get out because there is no power.
I was stucked inside the car for 5 hours... 1:30am in the morning until 6:30am. Underground parking has no phone network.
Im pretty sure I was breathing my own carbon dioxide in the end...
Is there an escape plan that I do not know about or have I found a deadly fault in our flawless cars?
alternatively you can buy a window shattering tool
You obviously couldnt toggle the lock with the door handle. That's strange there is no mechanical way to get out
Coupe
You can only open a door from the inside if it
is unlocked.
The vehicle locks the doors automatically,
when you drive faster than 9 mph
(15 km/h).
The doors are automatically unlocked after a
journey if you switch off the engine.
! The doors swing upwards and out when
opened. Therefore, make sure that there is
sufficient clearance above the vehicle.
X To unlock the door manually: press
the % button of central locking =.
or
X Pull locking knob : upwards.
X To open the door: pull handle ;.
X Swing the door upwards as far as it will go.
X To close the door: pull the door down by
handle ?.
X Allow the door to engage in the lower
position.
X To lock the door manually: press
the & button of central locking =.
or
X Push locking knob : downward
I was able to grab the attention of a gentleman heading off to work at 6:30am. From inside the SLS, I unlocked my G55 and asked him to grab the jump start battery, hook it up under the hood and straight away, I was able to let myself out from inside.
And I just realized, he could have just lifted the door handle from the outside and release me that way also!
Yes, its no joke. I have told my wife that we should get into the habit of opening the door before we shut down the engine of any modern vehicle.
Someone ought to read through the manual (I'm too lazy) because there has to be a way to manually actuate the door...usually though, it is extremely non-obvious and involves removing a trim piece to reveal a pull ring.
The real habit you should get into is not letting your battery go flat. If it's flat from age then replace it. If it's flat from non use, then don't do that (or at least put it on a trickle charger).
I did tested out yesterday morning..(my battery is still flat) and can confirmed that, you can open both doors from the outside. But not from the inside.
This is my first supercar and I honestly did not know the battery would go flat that easily from having the car stationary for a few weeks. Not to mention the existence of a trickle charger...
Im booking the car in for a battery replacement and will make sure the battery never go flat again. Thanks for the advise!
I wonder if perhaps you shut the car off before putting it in Park. This would force the car into Neutral (according to the manual) and probably circumvented the automatic unlock feature. When the car is put in Park, it unlocks itself. I know this because my passengers are always in a hurry to get out and clawing at the handle before I've hit the Park button (muwahahahaha).
Based on your test yesterday, I'm starting to think that while the exterior handle seems purely mechanical, the interior handle may be electrically actuating the catch release when you pull the handle and since there is zero juice, it simply can't do its job.
It would be interesting to see if you could recreate the situation. This time though, after the jump-start, roll the windows down so you can grab the exterior door handle or wiggle out.
Im pretty sure I pressed the Park button before shutting down the engine. the door did unlock (you can see clearly the tab next to the window frame popped up). I shut down the engine and all lights out. The door handle is unresponsive, same as when the doors are locked.
hmm...
I guess you're smarter than I am! I tried twisting it but did not try to pull it up higher... I might give it a go tomorrow! Thanks for that!!
Next time, cycle the door lock pin. The actuators they use on cars are pretty weak, and probably the voltage dropped enough with all the other things the car does electromechanically when it shuts down that the actuator didn't have enough juice to fully unlock.
Also, driving the car around the block a few times is not enough to put a good charge on a dead battery. Need to either put it on a charger for hours or drive it for a significant amount, at least 30 minutes. Longer if you run electrical, like headlights.
