FS w124 e500 ati BREMBO front and rear complete brake setup w201
Old Nov 10, 2010 | 12:31 PM
ruslan98270's Avatar
300e amg
Thumbs up FS w124 e500 ati BREMBO front and rear complete brake setup w201
Up for sale all 4 corners from e500 they been fully sprayed and brembo logo been put on and clear coated on top, pictures are on 18in wheels
Included:
front: 4piston calipers with rotors
rear: 2piston calipers with vented rotors
all hardware in caliper including 75% of brake pads
will fit:
w124 ( 260e 300e 400e e320 e420 e500 )
w201 ( 190e )
w202
w203
r129
w107
asking price $650
Let me know if you interested
425 319 3481
here is picture video: http://www.youtube.com/watch?v=HsKDB...layer_embedded
Old Nov 13, 2010 | 03:12 AM
Ungarisch's Avatar
Tectitgrau S210
are the speedlines for sale?
Old Nov 13, 2010 | 03:16 AM
300e amg
sold those a bit ago
Old Nov 14, 2010 | 03:24 AM
A4 Turbo's Avatar
2006 E55 AMG
will these fit clk 430 w208??
Old Nov 14, 2010 | 06:15 PM
pharaon19's Avatar
'92 W124
yes it will fit!
Old Nov 14, 2010 | 06:20 PM
300e amg
Yes they will bolt in, thanks pharaon19!
Old Nov 16, 2010 | 02:52 PM
Saijin_Naib's Avatar
1990 300ce 24v I6
Size of the wheel needed to fit the rotors? 17" right?
Old Nov 16, 2010 | 03:05 PM
300e amg
i tried stock 15 and i dont know how but it clears! (only stock w124 15s)
Old Nov 16, 2010 | 11:50 PM
VIPclk320's Avatar
CLK W208
I have a w208 clk and i am very intrested, but i have a few questions, are these these the factory ones that you have painted? or are they bermbos that are offered as after market? you mentioned that they are bolt ons on the w208 clk but what model rotors do i have to use with them off of which car? are they direct bolt on to the clk w208 or do i have to buy a bracket or i can use the existing bracket?
Old Nov 17, 2010 | 12:33 AM
300e amg
they are direct bolt on, in this sale everything included calipers rotors and pads, they are fectory ati brakes that been restored, e420 and 500e came with those
Old Nov 17, 2010 | 01:12 AM
VIPclk320's Avatar
CLK W208
can i use my existing w208 rotors and the caliper brackets?
Old Nov 17, 2010 | 01:16 AM
300e amg
no you cannot, these brakes are made to work together
Old Nov 17, 2010 | 01:54 AM
VIPclk320's Avatar
CLK W208
so if i need to get replacement rotors of what model benz do i have to order them from? and are they bigger than my existing rotors and do i have to modify them to fit my car? and also can you answer the bracket question as well too, do i use my existing caliper bracket or the new bracket?
thank you very much, i just want to know what i'm facing before pulling the trigger.
Old Nov 17, 2010 | 02:34 AM
300e amg
everything u use off my kit, they are 95 e420 rotors, no modification maybe trimming the dust shield, other then that it is bolt in, they are bigger then your 208
Old Nov 17, 2010 | 02:41 AM
300e amg
sorry rotor is the same just caliper is 4 piston insead of 2
Old Nov 17, 2010 | 03:55 AM
VIPclk320's Avatar
CLK W208
ok so based on the last response you are saying i can use my existing rotors? reason why i'm asking is because mine are brand new. and also do i use my existing bracket(the piece that attaches the caliper to the back of the hub with the two bolts) or do i have to have one custom made?
Old Nov 17, 2010 | 12:35 PM
Ungarisch's Avatar
Tectitgrau S210
these are non-floating calipers, thus they don't need brackets to "float" or move on since its just just the inside piston thats grabbing that disc, its but both sides.
Look at a how a single pot caliper works, then look at these and you'll get it.
Old Nov 17, 2010 | 06:46 PM
300e amg
sorry totally didn't get what brackets you were talking about, thanks Ungarisch
Old Nov 17, 2010 | 07:32 PM
VIPclk320's Avatar
CLK W208
Thank you very much for clearing that, so i can just buy this set and take off my old caliper and bolt this right up to my w208 without any modifications needed and also use my existing brand new rotors that i just purchased?
Old Nov 17, 2010 | 09:10 PM
300e amg
about the rotors i am not sure, they are same diameter, not sure if they same offset as yours
