S65 / CL65 calipers $300
1 Post
2004 Chrysler Crossfire
I will try to get some pictures up when I get home latter tonight. Here is a car on Ebay with the exact same rear calipers.
http://cgi.ebay.com/ebaymotors/2005-...item2eb240e4c8
Most likely not a direct bolt on, and the piston bores on that caliper are wayyy too large for the stock MC and overall brake bias (larger than the E/CLS/SL bores). Most interesting caliper though as it matches the stock C32/C55 front brembo caliper. What are the reasons you couldn't put it on your SRT6? Post some more pix when you get a chance please
1 Post
The pistons are very small and will work fine with the stock master cylinder. They use a 330mm rotor. I was planning on using them on my car and still may. The are not a direct bolt on as they use a larger bolt to hold them on. If nobody wants them I will use them. I have SLK55 rear rotors that i will use with them or try to find SLK55 rear calipers. I like these calipers because they match the Brembo four piston front calipers.
1 Post
I will measure the surface area and compare to my stock pistons. I did try to do a quick mock up and may do this again. It apears that these will not use a 348mm rotor on my car. The mounting ears aren't long enough. I am guessing that the mounting points on a S65 are further from center line than on a C/SLK/CLK/Crossfire. the mounting spacing of these calipers is that same as my car. If I was to use these, I would probably make a bracket from 1/4 inch steel that clocks the calipers slightly up. It wouldn't be that hard to do and they could be made to fit the SLK55 rotors. If I do this it would be a nice set up but not very repeatable since these calipers are very rare.
If you could use an SLK 330 rotor, then you would need to do nothing except bolt them on. If the holes are too large on the caliper, you could buy some precision collars with (12mm OD and 10mm ID is what I'm guessing you have) to take up the slack in the holes.
Where did you find these calipers anyway? They are definitely very hard to find, but should've come stock (or at least, a smaller variation of them) with the 4 pot fronts. Sorry for turning your FS thread into a brake swap thread....
2003 porsche 996 turbo
n/a
1 Post
I just measured the pistons with some calipers and they measure 1.0" and 1.1" this is real close but may not be a perfect measurement as the measureing caliper was a bit hard to get in there. If you total up the surface area and compare to single piston calipers you will find they are very close. Even when conveting from single piston front floater calipers to C32 you have a similar small increase in surface area. As long as you are keeing the surface area real close to stock you will not have a master cylinder or braking balance issue. I have designed and sold big brake kits to Mini Cooper racers in the past. I am real tempted to keep these because an adapter braket could be made to fit them to just about anything. I bought these off of Ebay a year ago and they just sat around while I got my V8 conversion done. I am currently running stock non SRT rear brakes with SRT/C32 front rotors with CL/S 500 front calipers. I am currently looking for C32/C/CLK500 front calipers. I have a set of C32 front rotors. I thought if I go 330mm in the rear I should go from 330 front to 345 to keep it looking right. I was thinking of selling thes and finding SLK55/C63 rear calipers but they seem to be just as rare.
I wonder if they really are 26/28 on the backside of the piston or they just neck down on the outside giving the impression of 26/28. Im interested in what youve got going on and im tempted to buy them myself lol. Already spent a bunch of money on another conversion though.... Im really curious to see how everything lines up on the 203 spindle. Let me borrow them :P
1 Post
Cool beans 320. Lantana lets continue our convo in PM. To all the vultures, consider these sold for now :P
1 Post
I have measured the pistons again very carefully. They taper a bit at the top but I was able to press the tips of my calipers (measuring tool) down past the dust seals just a bit and they are 26 and 28mm. I cannot read the part number on the dust seals even with my reading glasses on. My best guess is the last two numbers are 42 and the other is 41 or 47
So watcha think havoc? I found this online http://www.motorquality.it/easysite1...%202010-12.pdf which states diameter of 30mm and 32mm with those part numbers. I don't know if that's for their piston diameters though or if it's for their overall diameter. Lantana what's the overall outside diameter of your seals?
n/a
I've seen 26mm pistons on Brembo's motorsport calipers(which don't utilize dust boots) but haven't come across anything smaller than 28mm on their OEM front or rear calipers; and maybe is just coincidence but you'll note from the listing those dust boot sizes don't go any smaller than 28mm either.
The dust boot seals don't lie! As the listing shows, those numbers correspond to certain size pistons and I've actually checked this against known piston sizes in certain OEM Brembo calipers... Most late model OEM 4 pot rear Brembos utilize some combination of 32,30, or 28mm pistons. Porsche's use 30/28, AMGs (both the peanut shaped E55 and later E63 version) are 30/28, Cadillac CTS-Vs are 32/28.
