FS: Brembo GT Brake Kit
Lorinser ML(sold) E500 (sold) Sl500 2015 Escalade Bentley GT
For sale is my Brembo Big Brake Kit. Comes with slotted Brembo Rotors, Brembo Silver Calipers and all.
PM or email me for more info and pricing, sbarba@gmail.com
![](http://i54.tinypic.com/178y03.jpg)
![](http://i51.tinypic.com/14mvbq.jpg)
Do you happen to know the part number? I tried looking it up, but I could only find 8 piston fronts for the ML. Thanks.
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
To the OP , You wont find the kit number on the parts once you take off the brakes , you will find only the individual part numbers , hats, rotors maybe, and calipers...the kit number is the best to have , but if it was made originally for the ML it would be easy to figure out..size of rotor, and number of pistons per caliper.. I am not sure about the ML but these calipers dont look like 8 pot..
It is fairly easy with Brembo kits ... there is an application list for all mercedes models listing the kits available for different models . Look up the kit numbers for the ML ( there might be more than one , with different size rotors / calipers ) then compare with the kits for the chassis you want to adapt it to. if youre lucky the kit number is the same...if not you have to see what the difference is , BUT better be careful with changing parts ( ie: Hats/ Bells , or brackets , or rotor size ) as expensive as the kits are from Brembo, replacement parts are even more expensive to buy them individually specially the rotors ... you can call Brake Technologies ( The Brembo Distributors ) , for the individual part numbers if you need .
