w211 4matic amg brake group buy
Old Jan 18, 2016 | 01:47 AM
W211_350WagoN's Avatar
S211 E350 wagon, w211 e550 4matic, w210 2001 e320, 2023 glb250, 2013 Audi q7
Ok so finally Ive contacted someone willing to fabricate an adapter for us with 4matic's looking to upgrade our brakes to the amg 6 pot fronts & 4 pot rears.
Now that its all together I'm posting a group buy so we can get 15% off the cost.
They are only willing to sell the fronts as a package, That will include adapters (brackets) 2 piece rotors and pads. We need at least 3 buyers for the 15% discount and as Ive read in my search to get these calipers installed on my 4matic there should be at least another two that are buying.
There selling the front package with or without calipers and Im looking into my own calipers at the moment.
But still there package might be easier then searching for a set...
Pm me for Group buy and lets figure out when everyone is ready...
I'm told ETA will be 2-3 weeks from the last order/payment received.
Dave,
http://www.racingbrake.com/ProductDe...oductCode=2506
Old Jan 19, 2016 | 01:08 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
I am interested in the adapters, but would like to run the eight pistons. Would they sell the adapters separately?
Old Jan 19, 2016 | 11:07 AM
Not sure there interchangeable between the 6 & 8 piston calipers?
And they want to sell adapters with 2 piece rotors separate only. Not just adapters
Old Jan 19, 2016 | 11:58 AM
cm60k's Avatar
Also interesting about adapters only,
As i know; all (6-pot) & (8-pot) sharing the same adapter spread pattern...!!
ZAYED,,
Old Jan 19, 2016 | 12:45 PM
Do the clk/slk front calipers share the same spread as well ?,because I'm looking at a set online and would love to save the weight as there smaller 6 pot..
ZAYED,,
Old Jan 19, 2016 | 12:54 PM
cm60k's Avatar
Do you mean 6-pot from "W209 CLK55/CLK63 & R171 SLK55"..?
ZAYED,,
Old Jan 19, 2016 | 02:04 PM
Yes
ZAYED,,
Old Jan 19, 2016 | 02:11 PM
cm60k's Avatar
Generally; all 6/8-pot "mounting spread" is: (256mm), but the difference in the "mt-spread",
Except 6-pot "CLK55/CLK63/SLK55", which uses: (196mm), "mounting spread", with (110mm), "mt-spread"
W211 E55/E63 "mt-spread" should be: (110mm), but not so sure about your E350 4-matic spindle "mt-spread"..?!?
you can contact to "RB brakes" for more clarification, or measure your Exist spindle "mt-spread", to avoid any confusion..!!
ZAYED,,
Old Jan 19, 2016 | 02:40 PM
Ok so there adapters won't mount to the clk/slk calipers. I will contact them. But I know the spindle spread is the same other then the Amg m14 vs my m12 bolts.
ZAYED,,
Old Jan 19, 2016 | 03:07 PM
cm60k's Avatar
If you positively sure about "mt-spread", then 6-pot calipers & Rotors from "CLK55/CLK63/SLK55" should work, with some adjustable touch..!,,
just double check, and measure your caliper bolts "mt-spread", for more confident..
ZAYED,,
Old Jan 19, 2016 | 04:06 PM
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
6 and 8 piston calipers are not interchangeable in offset and mounting height.
8 piston calipers are too tall (no room for adaptor) for 360mm rotor set up although can adapt to 390mm rotor kit.
6 piston is a newer standard for all Mercedes performance brakes on C63, C63 BS, E63, GT S while 8 piston calipers are being obsolete and cost more to maintain (rebuild & pad replacement).
We will only sell the package with two piece rotors and adaptor as a minimum, you can source your own calipers with deduct but no adaptor only to assure the compatibility and overall performance improvement. as it's pointless to upgrade to larger calipers with heavy and bulky one piece rotor weighing 36 lbs.
We have offered the same upgrade kit for C63 upgrading to 390mm rotor with very satisfactorily result on both street and track applications.
To All Who Track Their Car
Old Jan 19, 2016 | 04:23 PM
cm60k's Avatar
Warren & friends,
i'm using 8-pot calipers from W211 E55 with W212 E63 brackets in my friend's W210 front spindle,
2 weeks ago, i put 390mm Rotors from SL65 BS, with 8-pot calipers from W220 S65 in my W202 front spindle,,
i tried many 6-pot calipers brackets(from W220 S600 & W204 C63 & R230 SL55/600), they all has the same mounting spread points with 8-pot calipers..
ZAYED,,
Old Jan 19, 2016 | 08:47 PM
Would I be able to buy the 390mm adapters for the c63/e63 in the future if I wanted to upgrade or would you guys need to make one again?
Also the clk/slk calipers won't work with the adapter kit I'm getting now because I might get a set of the front clk Calipers if the weight is to much. Or vise versa if it doesn't bother me weight wise with the 360mm and goto 390mm next year or so...
Old Jan 19, 2016 | 09:22 PM
CLS550
For the same adaptor, you can either use it for installing 360mm rotor with 6-pot caliper, or 390mm rotor with 8pot caliper.
Old Jan 19, 2016 | 09:41 PM
cm60k's Avatar
+1,
RB brakes(Warren) can customize any bracket or Rotor or Rotor Hat, that depend of spindle spec.,
bracket spread size + Rotor Hat height are the KEY for any custom work, which is soo easy to make with RB's magic touch..
ZAYED,,
Old Jan 20, 2016 | 05:10 PM
Just wanna confirm 2011 c63 front and rear calipers work with my wagon before I get the calipers off the c63?
Thanks again
Old Apr 10, 2016 | 12:30 PM
sskamboj's Avatar
09 W211 E-350 4Matic w/ Sport and AMG Packages
so did you end up using C63 calipers? I need to do the brakes on my car in a few weeks so I'm looking at options.
Old Sep 30, 2016 | 01:25 PM
need2speed's Avatar
2016 S212 E400 RENNTech 345 whp/360 wtq
Don't mean to crash this thread, but I'm hoping that RB will also offer rotor/caliper upgrades for the W212 4MATIC
Old Oct 2, 2016 | 08:38 PM
Tump43's Avatar
2014 E350 4Matic
me too
