Vendor Group Buys Group purchases offered by our supporting vendors.
Evosport Performance Rotors in Stock!!!!
Old Aug 1, 2007 | 11:40 AM
sales @ evosport's Avatar
Mercedes-Benz AMG
Thumbs up Evosport Performance Rotors in Stock!!!!
evosport upgraded performance rotors for the W211 E55 AMG and W219 CLS55 AMG cars are now in stock. I have 3 sets ready to ship.
Designed as a direct brake disc replacement for the OE 55 AMG brake discs on all four corners (No modifications are necessary. The disc will bolt directly to the car and work with OE AMG brake calipers). Not only will the upgraded multi-piece "floating" discs help mitigate brake fade, but are lighter than stock and reduce unsprung weight by a total of 34lbs. on all four corners! This means better acceleration, braking and cornering. In addition, you get to maintain the AMG calipers without going to a more expensive solution that requires replacing them. Available drilled/slotted or just slotted. Front 14.2"/360mm, Rear 13.0"/330mm. For use with OE AMG brake calipers only - E/CLS 55 AMG Kompressor.
We also have the upgraded Pagid performance brake pads and stainless steel braided brake lines available as well. Call or email us for more info.
For more info: http://www.evosport.com/product/prod...VO.BRK.M5K.R03
Drilled rotors shown below (drilled/slotted only available now):
Dale
Attached Thumbnails Evosport Performance Rotors in Stock!!!!-img_7462.jpg   Evosport Performance Rotors in Stock!!!!-img_7423.jpg
Old Aug 1, 2007 | 09:38 PM
jagsy's Avatar
2002 C230 Kompressor, Capri Blue
DO You have any that fit a 2002 C230 coupe?
Old Aug 2, 2007 | 01:13 AM
slowrey's Avatar
2006 Mercedes C55 AMG
Anything for C55's?
Old Aug 2, 2007 | 01:59 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Dude thats the last thing you need right now...
get your suspension and ASP.
Those rotors cost more than the whole AMG C32 brake kit.
Old Aug 2, 2007 | 06:29 PM
Mercedes-Benz AMG
Sorry guys nothing available for C-class
Dale
Old Aug 9, 2007 | 01:06 PM
Sunny55's Avatar
2005 SL55 AMG
Anything available for SL55?
Old Aug 9, 2007 | 01:08 PM
Sunny55's Avatar
2005 SL55 AMG
Let me know, as im looking to upgrade the sl55 brakes
Old Aug 9, 2007 | 01:35 PM
Mercedes-Benz AMG
Sunny55, yes we do have our rotors available for SL55. They are available in slotted, and drilled/slotted.
Dale
Old Aug 12, 2007 | 11:28 PM
Sunny55's Avatar
2005 SL55 AMG
Hey Dale,
Do these only come with 4 rotors? On the Evosport site, it says it reduces unsprung weight by 34lbs, I'm assuming thats all four rotors added together correct?
What about stainless steel brake lines and brake pads? Are they included as well?
Thanks in advance.
Sunny
Old Aug 13, 2007 | 03:48 PM
Mercedes-Benz AMG
Sunny55, yes this includes all 4 rotors. Pads are available but not included. We have a few options depending on how aggressive you want your brakes to be. We can provide factory pads, and Porterfields at the moment. The stainless lines are in stock. They are $150 for the set.
Dale
Old Oct 11, 2007 | 04:34 PM
JDM_SXE-10's Avatar
2003 E500
Are those available for non-AMG W211s too?
Old Oct 12, 2007 | 05:00 PM
Mercedes-Benz AMG
These rotors will not fit a non AMG car unless you upgrade to the complete AMG brake system. The rotors are a bolt on upgrade, for E/CLS/SL 55 only
Dale
