210 E55 Tranny Fluid change, help.
I have 59k miles on my 02 E55, and dealer says that I need to change the tranny fluid.
They want around 320-350 for it.
My question is, is that a job that I can do myself?
There is no dipstick in the car, they saying that they are using some special tool for that, do you know the part number for that tool or where else except for the dealer I can buy it at?
And if I will need any special size wrenches to change the fluid.
Does it require special Mercedes fluid and how much of it?
Will appreciate any response.
Thank you.
You will need a lift and a pump to change the fluid. I would pay to have it done. The oil aslo has to be at a certain temp when putting it in.
Mario
Again, why would the dealership tell you to change the fluid before 100,000 miles. Unless you beat the hell out of your car, supercharge your motor, or two a trailer, it will not need attention until at least 90,000 to 100,000 miles. In fact, you are opening the system to more contaminants by changing the fluid than leaving it alone.
Changing the fluid at 30,000 miles would be like changing your timing chain at 40,000 miles because some guy you heard about had a failure at 50,000 miles. (On a side note, this comment does not hold true for Jaguar XJ8's with the first generation secondary tensioners.) Sure, you may hedge the problem from happening on your car but the odds are very low that it will fail. You end up throwing money down the tube the same as someone who changes synthetic oil at 5,000 mile street driven intervals. The tranny failure at 65,000 miles may indicate a manufacturing issue, a leak, or one of abuse.
Hope that helped. You have to keep it to a case specific.
The 210 E55 is equipped with a transmission fluid cooler. With that in mind, our trannys are not likely to get hot enough to replace sooner than the 100,000 mile mark; of course, unless you drive in some extreme conditions and superheat your tranny.
Here is some additional material on the subject:
http://www.niehoff.com/techtips/trans.html
Our trannys are "sealed for life" - BUT, Merc will not say that this "life" - is quite short.
I called around and I got 50-50 response. 50% say that change needs to be done at 50k miles.
50 say, go ahead drive it a little bit more and come buy new tranny.
I don't want to do that.
I will ask my mechanic do it for me, cos dealer chares like 350. too much.
I got the tool (dipstick) and whole tranny fluid kit for total of a little less then 100$.
Dealer says that they do 4qts of it, I read that if you leave overnight it will drain around 7. I bought 5 so far (should be ok, if not will buy more) I will drain the plug and then the pan.
Torque Conv - on my car has no plug, so I won't drain it.
The whole thing will end up costing me about 120$. Which is good and far less, then spending several k to replace the tranny.
I have not idea how my car was serviced before I got it, so I'll better be safe.
And about life of trannys - if you drive around in a stinker you will have to change your fluid in about 3000000000 miles.
Our machines are a bit more powerful and you just CAN NOT STOP PUTTING YOUR FOOT DOWN - which is not good for automatics.
My mechanic has 540 Bummer, and he's tranny is sealed too.
So on 140k miles, it quit working completely. BUT, I was quite surprised, he changed the oil (200$. Dealer charges around 700$ he said ;-( ), and tranny was resurrected!! Drives like new now.
Automatics are pretty reliable when you:
1. Follow rules. 2. Service it.
But you have to do it.
Thanks everybody for your help.
I found two write ups. One you guys told me, and one on benzworld for G500.
(same tranny as ours.).
Kublin Method
This method, developed by Ted Kublin at Dixie Synthetics, uses the virgin oil TBN with a calculation of engine stress to determine the oil change interval. Here is the equation:
(Virgin TBN)(10)(oil capicity)(cubic inchies/horsepower)(MPG)= oil change interval
This equation divides cubic inches by horsepower as an indicator of the engine's natural stress level -- a high-output engine will be harder on oil than a low-output engine. Then it multiplies that against the miles per gallon of the specific engine being tested, as a representation of the environment that specific engine must work in (higher fuel economy represents less stress). Then it multiplies these by the oil capacity, as a greater oil capacity means the work is spread over a greater volume. Finally, the equation multiplies these by ten times the virgin oil's TBN (representing the oil's ability to handle the stress loads) to arrive at the oil change interval.
This method tends to emphasize long drain intervals, which with today's oils in today's cars are often quite reasonable. Nevertheless, it would be a good idea to approach extended drains with a certain amount of prudence. Kublin prefers to think of the TBN as an empirical constant and recommends using a TBN of 12 for Amsoil, 8 for Mobil 1, and 4 for conventional oil, regardless of its actual TBN value.
6k miles is 10,000 km. This is a lot for any type of engine.
I don't care what they say, but oil needs to be changed between 6-7k miles if you want what's best for your car.
I now drive 01 Pathfinder 3.5 - I use syntehtic oil only.
Last time I missed my 6k mark and got it over to 8k miles.
I noticed that engine was running a little bit more rough, and my MPG was 13.
Oil change done - you can barely hear it, it is quicker and now I'm gettin 16mpg.
Oil and filter are dirt cheap - change is free. Why not?
Point well made I think.
Do what you want if it makes you feel better. However, if your air filter and the rest of you car is in good shape and you don't abuse the hell out of your car or drive in an extremely dusty environment, then you are wasting your money. Your money, your car, do what the F*** you want to do but please try to educate yourself instead of calling something "sceintific bull****."
In fact Mobil now says 15k miles.
But, If I'm able to tell the difference in how engine is working, if I hear it, and I my mpg starting to get worse - and when I change it, it all gets better - then all this 15k miles is Scientific bull****. Pure theory.
For example - Baby. Baby poops. Do you change his/her diaper right away or let it sit till the **** starts pouring outside?
Same with cars.
And by the way, if you drive mostly in city, that puts more stress on the engine and oil then hwy driving. So, shorter interval might be needed for those who does most of the driving in city speeds.
And you are right - it is our money and we do whatever we like to with it.
And cos of the guys like you, it is REALLY tough to buy good used vehicle.
Change the fluid, whatever mileage you got in there. There is a dipstick to be purchased which will allow you to check the level. I have one and I'll get the part # later for you. I went to an indie and he charged me like $100 plus tranny Mercedes fluid. The pan needs to be resealed. Mmm that's about it.
I take great care of my vehicles and have never had any trouble selling any of my used Mercedes vehicles. I do all the preventative maintenance and do not abuse the cars in any way. I also do not throw money away by doing preventative maintenance too early.
I bought this tool on ebay.
40$. Dealer charges 75. I thougt of returning it aftewards, but I figured I might use it or sell it, or just give it away to someone who will buy my car later.
And about the preventive care. You do what you feel is right.
You can go by the book and be ok, or you can go by your heart and be ok.
This is just depends on person.
I guess person that likes to always do smth with the caractually likes to change oil, buy new filters e.t.c. Even if it's too early. For me it is also fun.
I can take a shower once a week or I can shower every day. That's just how I feel. This really has nothing to do with the topic or discussion going on but since mainroman said an example I thought I'd chime in.
